Defining audio precision in style
The GigaWorks T3 takes audio enjoyment to a whole new level, with the integration of innovative design, premium components and state-of-the-art technologies. This premium 2.1 speaker setup combines a perfect blend of quality and elegance to deliver precise Hi-Fi quality audio like no other.
With its minimalist design, it is the perfect addition to your desktop, living room or bedroom. Designed for discerning audio enthusiasts, the GigaWorks T3 is ideal for high-quality music, gaming or movies - a true top performer for all your multimedia entertainment audio needs.
Compact and stylish satellite speakers
The 2" full-range audiophile grade driver in each satellite delivers full mid-range and clear highs. The small footprint also means that your desktop or living room would be neat and clutter-free.
Powerful subwoofer without the bulk
Featuring Creative SLAM™ (Symmetrically Loaded Acoustic Module) technology, the compact subwoofer delivers a thunderous output, with three drivers in a portless, enclosed casing. You can even adjust the bass level easily.
SLAM (Symmetrically Loaded Acoustic Module)
Creative SLAM™ subwoofer delivers deep, tight bass. Highly engineered and extensively tuned, the portless design utilizes a master driver and dual pressure drivers housed in a highly compact inert enclosure. This three-driver configuration delivers the quick transient response of a small driver together with the high-output capability and deep bass extension of larger drivers.
Wired remote control
The wired remote incorporates a low friction precision volume dial that doubles as a power/standby switch while the AUX-in and headphone-out ports make it easy to connect to external devices or headphones for private listening. With the eco-friendly Low Standby Power technology (patent pending), a negligible amount of power is consumed in standby mode, as compared to other speaker systems.
Big sound from a small package
Be amazed by the powerful audio that comes from this compact system. Experience big sound in your music, games and movies today!
- Creative GigaWorks T3 - speaker system - for PC
- Product Type
- Speaker system - for PC - 2.1-channel
- System Components
- 2 speakers, subwoofer
- Speaker Type
- Active
- Continuous Power
- 80 Watt
- Frequency Response
- 30 - 20000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 2 x satellite speaker 15 Watt 8 Ohm , 1 x subwoofer 50 Watt
- 2-year warranty
- Product Type
Speaker System
- System Components
- Speaker Type
- Active
- Continuous Power
- 80 Watt
- 30 - 20000 Hz
- Amplifier
- Integrated
- Controls
- Power on/off
- Detachable Grilles
- Speakers Included
- 2 x satellite speaker - 15 Watt - 8 Ohm - wired , 1 x subwoofer - 50 Watt - wired
- Driver Details
- Subwoofer: 3 x subwoofer driver - 6.5"
- Driver Details (2nd speaker)
- Satellite speaker: full-range driver - 2"
- Connector Type
- Headphones , Audio line-in
- Included Accessories
- Audio cable, remote control
- Remote Control
- Remote control - cable
- Power Source
- AC power adapter
- Dimensions (WxDxH) / Weight Details
- Satellite speaker: 7.6 cm x 9.3 cm x 14.9 cm / 352 g , Subwoofer: 23.6 cm x 28.7 cm x 21.3 cm / 5.9 kg
- Limited warranty - 2 years
