Corsair Vengeance K90 Performance MMO Gaming Keyboard
Quicklinx: 7RQ1WS00 Mfr#: CH-9000003-UK
The Vengeance K90 Gaming Keyboard: designed for performance gaming
Cherry MX Red mechanical key switches
Cherry® MX Red key switches are the best of the best -- they provide the sensitivity and low operating force that professional gamers love. Reaction times are ulra-fast and responsive for quicker double and triple taps. The action is predictable and linear unlike lesser gaming keyboards that have a tactile bump or the annoying click of a typist's keyboard.
18 dedicated, customizable G-Keys
Easily access to your most frequently used macros, presets and key combinations even during the most intense action. You can record up to 54 programmable functions accessible from three separate banks, ideal for grouping macros by function, or access. Macros can be created on-the-fly, customized, and activated with a single keystroke.
Full key matrix anti-ghosting
Our expertly designed anti-ghosting technology provides flawless control even when you're pressing multiple keys at once. The K90 has individual switches with dedicated diodes for each switch so every key press results in an input and is 100% ghost free without tradeoff or compromise.
20-key rollover (20KRO) on USB
Typical USB gaming keyboards are limited to the USB standard six-key rollover. The K90 features increased performance with a 20-key rollover implementation on USB at a blazing fast 1ms (1000 reports per second) reporting rate.
Professional grade brushed aluminum chassis with laser etched, backlit keys
The rugged aluminum chassis provides increased durability and stability compared those that are primarily plastic. The stiff suspension chassis and the laser etched keys are made for durability so they won't degrade over time. And the K90 has over 90 LEDs that provide outstanding illumination even in dim light.
Vengeance Gaming Keyboard Software
Create up to 50 profiles and share, import and export macros with the Vengeance keyboard gaming software. It's a free download at corsair.com.
On-board memory lets you take it with you
36Kb of memory built into the K90 lets you take your customizations and profiles with you and use them on any system.
Easy access multimedia controls
Control all of your music with the easy access media controls.
USB pass-through
A USB port on the back of the Vengeance K90 gaming keyboard makes connecting your mouse or other USB devices a simple task.
Soft-touch wrist rest
The soft-touch wrist rest helps you play for hours without fatigue.
Corsair Vengeance: Designed for performance gaming
The gear that brings your gaming to the highest performance
Incredible responsiveness. Precise accuracy. Customizable, reliable controls. Intelligent design. The smallest details and the highly crafted refinements that make all the difference. Vengeance gaming peripherals aren't typical gaming devices, but elite mice, keyboards and headsets that allow you to perform at your highest level. Brought to you by Corsair -- people enthusiastic about performance gaming.
The Corsair Advantage
With a long history of building enthusiast-grade memory and components, we've earned a reputation for quality, compatibility, and performance. Need help? We're available by phone call, email or web forum.
Contents and Specifications
Package contents:
-Vengeance K90 gaming keyboard
-Soft touch, detachable wrist rest
-Warranty card
System requirements:
-PC with high power USB 2.0 port (+500mA)
-Windows® 7, Windows Vista®, or Windows® XP
-Internet connection (for SW driver installation)
-At least 35MB of hard disk space
-Two USB connectors are required for USB pass-through
  • Cherry MX mechanical key switches
    Cherry MX key switches are the best of the best - they provide the sensitivity and low operating force that professional gamers love. Reaction times are ulra-fast and responsive for quicker double and triple taps. The action is predictable and linear unlike lesser gaming keyboards that have a tactile bump or the annoying click of a typist's keyboard.
  • 18 dedicated, customizable G-keys
  • Full key matrix anti-ghosting
    The expertly designed anti-ghosting technology provides flawless control even when you're pressing multiple keys at once. The K90 has individual switches with dedicated diodes for each switch so every key press results in an input and is 100% ghost free without tradeoff or compromise.
  • 20-key rollover on USB
    Typical USB gaming keyboards are limited to the USB standard six-key rollover. The K90 features increased performance with a 20-key rollover implementation on USB at a blazing fast reporting rate.
  • Professional grade brushed aluminum chassis with laser etched, backlit keys
  • On-board memory lets you take it with you
    The memory built into the K90 lets you take your customizations and profiles with you and use them on any system.
  • Easy access multimedia controls
  • USB pass-through
  • Soft-touch wrist rest
CORSAIR Vengeance K90 Performance MMO Mechanical Gaming - keyboard - UK
Keyboard
USB
Wired
Localization and Layout
Hot Keys Qty
18
Hot Keys Function
Multimedia, macros buttons
Integrated USB Hub, detachable wrist rest, tilt legs, illuminated keys, laser engraved printing keys, gold-plated connector, On-The-Fly macro recording, 20-key rollover, CHERRY MX Red technology, 36 KB onboard memory, Windows Lock key
Microsoft Certification
Compatible with Windows 7
Keyboard
USB
Input Device
Hot Keys Qty
18
Hot Keys Function
Keyboard Technology
Mechanical
1 x USB cable - 2 m
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Resources
The following resources are available for the Corsair Vengeance K90 Performance MMO Gaming Keyboard
