CORSAIR high performance Vengeance memory module 16GB (4x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
Key Features
- 16GB (4x4GB) DDR3 for AMD, Intel Dual processors and upcoming 2nd Generation Intel Core platforms
- 1600MHz
- 9-9-9-24 latency
- Vengeance Blue heat spreader for styling and performance. A perfect match for Intel Sandy Bridge Motherboards
- Intel XMP (Extreme Memory Profile) Support
- Limited Lifetime Warranty
- Density: 16GB (4x4GB Module)
- Speed: 1600MHz
- Timing: 9-9-9-24
- Type: DDR3
- Format: DIMM
- Pin Out: 240 Pin
- Voltage: 1.5V
- Corsair Vengeance memory - 16 GB : 4 x 4 GB - DIMM 240-pin - DDR3
- Storage Capacity
- 16 GB : 4 x 4 GB
- Upgrade Type
- Generic
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Memory Speed
- 1600 MHz ( PC3-12800 )
- Data Integrity Check
- Non-ECC
- Latency Timings
- CL9 ( 9-9-9-24 )
- Intel Extreme Memory Profiles (XMP), dual channel, Vengeance heatspreader , unbuffered
- Supply Voltage
- 1.5 V
- Limited lifetime warranty
- Storage Capacity
- 16 GB : 4 x 4 GB
- Upgrade Type
- Generic
- DRAM
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Memory Speed
- Latency Timings
- CL9 ( 9-9-9-24 )
- Non-ECC
- RAM Features
- Supply Voltage
- 1.5 V
- Compatible Slots
- 4 x memory - DIMM 240-pin
