Enjoy legendary audio with zero hassle. You get 2.4GHz wireless freedom at up to 40 feet, and ten hours of uninterrupted gaming at a time. Genuine Dolby 7.1 surround gives you lethally accurate positional audio, and the 50mm neodymium drivers produce staggering bass, highs, and dynamic range. Marathon gaming sessions are easy with the microfiber-wrapped earpads, and you'll be heard loud and clear with the unidirectional noise-cancelling microphone.
- Legendary audio, zero hassle: 2.4GHz wireless freedom up to 40ft + 10 hours of uninterrupted gaming
- Epic immersion and true multi-channel audio: genuine Dolby 7.1 surround delivers lethally accurate positional audio
- Unlock legendary audio: Oversized 50mm neodymium drivers bring the action to life with brilliant range and precision
- Embark on marathon gaming sessions: comfortable microfiber-wrapped memory foam earpads enable extended play.
- Take command: the advanced unidirectional noise-cancelling microphone makes you loud and clear
Genuine Dolby 7.1 surround delivers lethally accurate positional audio. It accurately reproduces multi-channel gaming audio for precise situational awareness and the competitive edge you can only get through positional audio. It also helps reduce "headphone fatigue," which is essential if you play competitively or if you just enjoy playing for hours at a time. -
Oversized 50mm neodymium drivers bring the action to life with brilliant range and precision. They greatly reduce the overloading and distortion that can occur with gaming headsets that use smaller drivers that aren't up to the task. You'll get more accurate sound reproduction, particularly for the all-important low-frequency effects. -
The comfortable microfiber-wrapped memory foam earpads enable extended play. They provide a reliable fit that conforms to the contours of your head without binding or pinching. -
Take command
The advanced unidirectional noise-canceling microphone makes you loud and clear, and screens out extraneous noise from outside your game.
- CORSAIR Gaming H2100 Dolby 7.1 - headset
- Product Type
- Headset - 2.4 GHz - wireless
- Localisation
- Europe
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wireless
- Wireless Technology
- 2.4 GHz radio frequency
- Radio Frequency Range
- 2.4GHz
- Sound Effects
- 7.1 Channel Virtual Surround Sound
- Audio Specifications
- Frequency Response 20 - 20000 Hz
- Impedance
- 32 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional
- 2-year warranty
- Product Type
- 540 g
- Max Operating Distance
- 12 m
- Localisation
- Europe
Audio Output
- Full size
- Wireless
- Sound Effects
- 20 - 20000 Hz
- Impedance
- 32 Ohm
- Dynamic Range
- 105 dB
- Diaphragm
- 50 mm
- Magnet Material
- Neodymium
Microphone
- Boom
- Uni-directional
- Sensitivity
- -37 dB
- Impedance
- 2.2 kOhm
- 100 - 10000 Hz
- Audio Input Details
- Uni-directional - 100 - 10000 Hz - Output Impedance 2.2 kOhm
Wireless Link
- 2.4GHz
- Transmission Range
- 12 m
- Connector Type
- USB (4 PIN USB Type A)
- Included Accessories
- Wireless adapter
- Cable Details
- USB charge cable - 1.5 m , USB extension cable - 1.5 m
- Battery
- Headphone battery
- Run Time (Up To)
- 10 hours
- Limited warranty - 2 years
