Corsair CS MODULAR Series power supplies are an excellent choice for mid-range system builds and most desktop PC computer upgrades. CS-M PSUs are semi-modular and feature 80 PLUS Gold rated efficiency that saves you money on your power bill while generating less heat than many other power supplies. The modular flat black cables allow users fast, neat builds. DC to DC technology ensures 100% compatibility with 4th Generation Intel Core processors.
- The Perfect Choice For Your PC - CS MODULAR Series power supplies are a perfect choice for either new builds or PC desktop upgrades with high-efficiency and low noise.
- 80 PLUS Gold-certified Efficiency - Highly efficient CS MODULAR Series power supplies produce less heat and have lower operating costs.
- Flat black, Low-Profile Modular Cables - You can remove unneeded cables and leave them in the box for fast, easy, and great-looking builds.
- Reliable, Continuous Power Delivery - CS MODULAR Series power ratings are continuous, not peak, for superior protection for your valuable PC.
- Corsair uses high-quality internal components, and CS MODULAR Series power supplies are guaranteed to deliver clean, stable, continuous power.
80 PLUS Gold-certified efficiency
The super-efficient operation of the CS series modular results in lower energy use and lower operating costs. Since it generates less heat, the fan doesn't need to work as hard, and you'll enjoy near silent operation. -
Modular cabling with clearly marked connectors
The flat, sleeved black cables are modular, so you'll only use the cables you need and you'll get great-looking results. The clearly-marked connectors make installation fast and straightforward. -
Supports Intel Core processor
The low-power sleep state of the latest Intel processors can cause performance and compatibility issues with some power supplies. CS series modular power supplies fully support the modes, making them an excellent choice for PCs.
- CORSAIR CS Series CS650M - power supply - 650 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.4/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Gold
- 2.107 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 650 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V - 51 A , -12V - 0.8 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector , 4 x 8 pin PCI Express power with detachable 2 pin section
- Modular Cable Management
- 15 cm x 14 cm x 8.6 cm
- 3-year warranty
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 650 Watt
- Output Current
- Efficiency
- 92%
- 80 PLUS Gold
- MTBF
- 150,000 hours
- Over voltage protection, overpower protection, temperature auto control, undervoltage protection, short-circuit protection, semi-modular
- UL, TUV, BSMI, cUL, CB, CCC, FCC, RoHS, WEEE, ICES, KC, EAC, RCM
- Limited warranty - 3 years
- 15 cm
- 14 cm
- 8.6 cm
- 2.107 kg
- Shipping Width
- 26.8 cm
- Shipping Depth
- 19 cm
- Shipping Height
- 9.8 cm
- Shipping Weight
- 2.327 kg
