The CX Series is an ideal solution for those who want a no-nonsense, reliable power supply that's designed for maximum compatibility. Unlike other PSUs in its price range, the CX series is rated for continuous power output for maximum compatibility and reliability, and it carries the 80 PlusĀ® Bronze certification for efficiency. A great budget choice.
- Corsair engineering and quality control
- Plentiful connectors and long cables
- 80 PLUSĀ® Bronze Certified efficiency
- Large diameter, thermally controller fan
- Black housing and all-black sleeved cables and connectors
- 3 Years Manufacturers Warranty
- Model: CX600
- AC Input: 100-240V
- Input Current: 10-5A
- Frequency: 47~63Hz
- Max Load Max Output: +3.3V 120W 25A, +5V 25A 130W, +12V 46A 552W, -12V 9.6W 0.8A, +5Vsb 15W 3A
- Total Power: 600W
- Warranty: 3 Years Manufacturers Warranty
- CORSAIR CX600 - power supply - 600 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.31/ EPS12V 2.91
- 80 PLUS Certification
- 80 PLUS Bronze
- 2.06 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 600 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V - 46 A , -12V - 0.8 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
- Cooling System
- 120 mm fan
- Black
- 15 cm x 14 cm x 8.6 cm
- 3-year warranty
- PSU Form Factor
- ATX
- Black
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Input Voltage Range
- AC 190 - 264 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 600 Watt
- Output Current
- 80 PLUS Bronze
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail, non-modular
- FCC Class B certified, UL, TUV, C-Tick, cUL, CB, CCC, Energy-Related Products (ErP) Lot 6
- Limited warranty - 3 years
- 15 cm
- 14 cm
- 8.6 cm
- 2.06 kg
- Shipping Width
- 19.05 cm
- Shipping Depth
- 26.67 cm
- Shipping Height
- 9.855 cm
- Shipping Weight
- 2.32 kg
