The Corsair Builder Series CX430 PSU is designed for worry-free compatibility for your home desktop PC system build or upgrade. With features usually reserved for premium power supplies, they are a great choice for systems where continuous and reliable power delivery and low noise are essential. Inside you will find a power supply that conforms to universal ATX standards, a power cable, and a clear, detailed Quick Start Guide. Corsair Builder Series power supplies get your system up and running quickly and easily, for years of trouble-free operation.The Builder Series CX430 is the ideal choice for PC builders and upgraders who need a great value, quiet and energy efficient PSU for a low/medium specification home or office PC.
- Corsair engineering and quality control
- Plentiful connectors and long cables
- 80 PLUSĀ© Bronze Certified efficiency
- Large diameter, thermally controller fan
- Black housing and all-black sleeved cables and connectors
- 3-Year Warranty
Physical
- Form Factor ATX
- Case Colour Black
- Width 150mm
- Depth 140mm
- Height 86mm
- Weight 2.06Kg
Specifcations
- Model: CX430
- AC Input: 100-240V
- Input Current: 6.3-3.15A
- Frequency: 47Hz - 63Hz
- Max Load Max Output: +3.3V 20A 110W, +5V 20A, +12V 32A 384W, -12V 0.8A 9.6W, +5Vsb 3A 15W
- Total Power: 430W
- Warranty: 3 Years Manufacturers Warranty
An ideal choice for value-conscious system builders and upgraders
CX series power supply units are an excellent choice for basic system builds and desktop PC computer upgrades. -
Reliable and compatible
CX series is built and tested to strict standards for trouble-free installation and smooth operation. -
Good looks
The matte black finish, black-sleeved cables and black connectors help give your system a restrained, high-tech look. -
Low noise
80 PLUS Bronze certified efficiency and clever fan design allow for little or no detectable fan noise during regular operation. -
Ample connectors and long cables
Long cables make CX series suitable for installation even in full-height tower cases, and the generous cable count allows you to power multiple components and storage devices. -
Large-diameter, thermally controlled fan
Once you've installed a PSU, you shouldn't have to think about it. Employing a thermally controlled fan makes the CX series virtually silent at idle, and the large diameter reduces noise even when you're pushing your system hard. -
Black goes with everything
You're building a PC, not a battleship, and appearance counts. The matte black finish and all-black sleeved cables and connectors help give your system a high-tech, restrained look.
- CORSAIR CX430 - power supply - 430 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.31/ EPS12V 2.91
- 80 PLUS Certification
- 80 PLUS Bronze
- 2.06 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 90-264 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 430 Watt
- Output Current
- +3.3V - 20 A , +5V - 20 A , +12V - 32 A , -12V - 0.8 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x 6 pin PCI Express power , 3 x 4 PIN internal power , 4 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
- Cooling System
- 120 mm fan
- Black
- 15 cm x 14 cm x 8.6 cm
- 3-year warranty
- PSU Form Factor
- ATX
- Black
- Localisation
- United Kingdom
- Input Voltage
- AC 90-264 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 430 Watt
- Output Current
- 80 PLUS Bronze
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail, non-modular
- FCC Class B certified, UL, TUV, C-Tick, cUL, CB, CCC, Energy-Related Products (ErP) Lot 6
- Limited warranty - 3 years
- 15 cm
- 14 cm
- 8.6 cm
- 2.06 kg
- Shipping Width
- 19.05 cm
- Shipping Depth
- 26.67 cm
- Shipping Height
- 9.855 cm
- Shipping Weight
- 2.32 kg
