The intelligent 120 mm fan speed controller with honey combo mesh increases airflow for better heat dissipation. The custom 12 V to 3.3 V and 5 V module design offers notably higher efficiency and voltage stability than other designs. It offers high efficiency, improves the heat dissipation and reduces the unnecessary cables which results in much lower crosstalk, signal noise.
Intelligent 120 mm fan
The intelligent 120 mm fan speed controller with honey combo mesh increases airflow for better heat dissipation. -
Modular cable system
Only use the cables you need, no unnecessary cable mess! Building a clean and tidy system with excellent airflow has never been this easy and convenient. -
Double layer EMI filter
It ensures low levels of electromagnetic interference. -
Custom DC-DC module
The custom 12 V to 3.3 V and 5 V module design offers notably higher efficiency and voltage stability than other designs. -
Unique 3D circuit design
- Cooler Master GM Series - power supply - 550 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.31
- 80 PLUS Certification
- 80 PLUS Bronze
- Localisation
- Europe
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 550 Watt
- Output Current
- +3.3V - 20 A , +5V - 20 A , +12V - 42 A , -12V - 0.3 A , +5VSB - 2.5 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 2 x 8 pin PCI Express power with detachable 2 pin section , 6 x 15 pin Serial ATA power , 3 x 4 PIN internal power , 1 x 4 PIN mini-power connector
- Modular Cable Management
- 15 cm x 14 cm x 8.6 cm
- ATX12V 2.31
- PSU Form Factor
- ATX
- Localisation
- Europe
- Input Voltage
- AC 100-240 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 550 Watt
- Output Current
- 80 PLUS Bronze
- MTBF
- 100,000 hours
- Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, single 12V rail, DC-DC technology
- UL, TUV, BSMI, CCC, FCC, EAC
- 15 cm
- 14 cm
- 8.6 cm
