Cisco Small Business SPA 514G VoIP Phone
Quicklinx: 8DVSWS00 Mfr#: SPA514G
The Cisco SPA514G 4-line IP phone with 2-port Gigabit Ethernet switch provides the advanced voice and data communications features small businesses need to stay productive and responsive to customers. This stylish, affordable phone offers a rich array of functions, including simple station moves, shared line appearance across dispersed locations, and intelligent call handling and conferencing support. Based on Session Initiation Protocol (SIP), the SPA514G 4-line IP phone is fully interoperable with leading voice over IP (VoIP) equipment, for fast deployment and high availability. Highly secure remote provisioning streamlines installation, configuration, and management.
  • Voice and data together
    Integrated communications right on the phone lets employees make voice calls and access corporate data, such as company directories, quickly and easily, no matter where they happen to be working.
  • Intuitive, easy-to-use phone features
    Employees can take advantage of their phone systems features, including: speakerphone, redial, call transfer, conferencing, paging, intercom, volume control, message-waiting and voicemail indicator lights, mute key, headset use, and call history directories.
  • Comprehensive interoperability and SIP-based feature set
    This phone has been tested to make sure it provides comprehensive interoperability with equipment from SIP-based voice over IP (VoIP) leaders.
Cisco Small Business SPA 514G - VoIP phone
VoIP phone
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
SIP, SIP v2, RTCP, RTP, SRTP
Voice Codecs
G.722, G.723.1, G.729a, G.711u, G.711a, G.726
Lines Supported
Multiline
Speakerphone
Caller ID
Voice Mail Capability
Call Services
Voice Mail, Caller ID, Call Hold
Display
LCD display - monochrome
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX/1000Base-T
VoIP phone
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Speakerphone
Menu Operation
Function Buttons
Speakerphone button, headset button, mute button, hold button
Volume Control
Ringer Control
Indicators
Voice message waiting indicator, speakerphone indicator, headset, mute indicator
Firmware Upgradable
Additional Features
Built-in web server
IP Telephony
Main Features
VoIP
VoIP Protocols
Voice Codecs
Lines Supported
Multiline
Quality of Service
IEEE 802.1Q (VLAN), Differentiated Services (DiffServ), IEEE 802.1p, Type of Service (ToS)
IP Address Assignment
DHCP
Security
256 bit AES
Power Over Ethernet (PoE) Support
Network Protocols
IP, TCP, TFTP, UDP, ICMP, ARP, HTTP, DNS, HTTPS, SRTP
Network Ports Qty
Voice Features
Voice activity detection (VAD)
Network Features
Network Address Translation (NAT)
Display
Display Location
Base
Headset jack / sub-mini-phone 2.5mm
Hearing Aid Compatible
Network cable
Stand
UL, FCC, RoHS, WEEE, A-Tick
8DVS C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
