Cisco Small Business RV325 Desktop Router
Quicklinx: 9J7VWS00 Mfr#: RV325-K9-G5
The Cisco RV325 dual gigabit WAN VPN router is no exception. Featuring intuitive user interfaces, it will have you up and running in mere minutes. The capable router provides reliable, highly secure connectivity for you and your employees and work so well that you won't even know the router is there.
Cisco Small Business RV325 - router - desktop
Router - 14-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Performance
NAT throughput: 900 Mbps , VPN throughput (IPSec): 100 Mbps , VPN throughput (SSL): 20 Mbps
Virtual interfaces (VLANs): 17 , PPTP VPN tunnels: 10 , SSL VPN tunnels: 10 , VPN tunnels (site-to-site): 25 , IPSec VPN tunnels: 25 , Concurrent connections: 40000 , ACL rules: 50
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, Bonjour, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing, RIPng
Remote Management Protocol
SNMP 1, SNMP 3, SNMP 2c, HTTP, HTTPS
DMZ port, NAT support, hardware encryption, VPN support, PAT support, load balancing, Syslog support, SPI, DoS attack prevention, content filtering, E-mail alert, IPv6 support, firmware upgradable, QoS, IPSec NAT-T, DHCP server, reset button, bandwidth control, DHCP relay, DNS relay, DHCP client
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q
24.3 cm x 17.7 cm x 4.5 cm
Taiwan, Thailand, Singapore, India, Europe
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, FCC Class B certified, UL, BSMI, cUL, CB, CCC, ANATEL, KC
Status Indicators
Port transmission speed, power, WAN, DMZ, link/activity, DMZ/Internet, diagnostic, USB, VPN
LAN: 14 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / DMZ: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
External power adapter
1 x network cable
Software Included
Drivers & Utilities
24.3 cm
17.7 cm
4.5 cm
Limited warranty - lifetime
10 - 85% (non-condensing)
9J7V C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
