Cisco Single Radio 802.11n Access Point w/PoE (EU)
Quicklinx: 8DTZWS00 Mfr#: WAP121-E-K9-G5
  • IEEE 802.11n
The Cisco WAP121 is a sleek, affordable, and easy to deploy wireless access point that delivers fast, reliable wireless connectivity and enables small businesses to easily expand their wired networks. The device combines ease of use with business-class features such as support for IPv6, Power over Ethernet for simpler deployment, quality of service to prioritize network traffic, and advanced security to deliver the reliability and performance needed for small business networks. The sleek and elegant design with flexible mounting options allows it to seamlessly blend into any small business environment. The Single Point Setup feature makes deployment of multiple access point easy, and cost effective. It can be managed with an intuitive browser-based GUI or embedded setup wizard.
Cisco Small Business WAP121 - radio access point - Wi-Fi
Radio access point
External
Europe
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
DC 12 V
12.4 cm x 12.4 cm x 3.5 cm
168 g
Radio access point
12.4 cm
12.4 cm
3.5 cm
168 g
Europe
External
Wireless
Data Transfer Rate
300 Mbps
Spread Spectrum Method
OFDM
Network / Transport Protocol
DHCP, Bonjour
Remote Management Protocol
Telnet, SNMP 3, HTTP, HTTPS, SSH
Frequency Band
2.4 GHz
Status Indicators
Power, WLAN, LAN
DHCP support, load balancing, VLAN support, Syslog support, E-mail alert, IPv6 support, Wireless Distribution System (WDS) support, firmware upgradable, wall mountable, Spanning Tree Protocol (STP) support, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, Wi-Fi Protected Setup (WPS), Multiple SSID support, wireless bridge mode, IPv4 support
Encryption Algorithm
WPA, WPA2
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.11b, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11e, IEEE 802.11n, Wi-Fi Protected Setup
Aerial
Antenna
Internal
Gain Level
2 dBi
1 x 100Base-TX (PoE) - RJ-45
1 x network cable
Mounting Kit
Included
FCC Class B certified, IC
PoE
External power adapter
DC 12 V
OS Provided
Linux
Limited warranty - lifetime
10 - 85% (non-condensing)
8DTZ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
