Power Your Network Expansion
A strong business network needs a solid foundation. One of the Cisco Small Business Managed Switches, the SRW2024P Gigabit Switch provides that essential core. It supplies up to 15.4W of power for each of 12 connected devices, or 7.5W to each of the switch's 24 ports. This reduces the cabling needed to power external networked devices.
You can connect up to 24 networked devices to the switch, which itself supports gigabit networking for exceptional performance. The SRW2024P also prioritizes dataflow with a variety of traffic-shaping mechanisms, helping to ensure the clarity of heavy-traffic communications like video teleconferencing. The switch's robust management functions are easy to access through a number of clients, and its internal monitoring software keeps tabs on your network's every operation.
Additional features of the Cisco SRW2024P 24-port Gigabit Switch include:
Nonblocking switching capacity of up to 48 Gbps
Up to 256 active port- and 802.1q-based VLANs (4096 range)
Secure access limitations using 802.1x port authentication and MAC filtering
Standards-based IEEE 802.3af Power over Ethernet (PoE) - 180W of total PoE power
High performance and reliability
Get the high availability and performance you need to support vital business applications while reducing downtime. -
Advanced features
Control network traffic with advanced features such as quality of service (QoS), Layer 3 static routing, and IPv6 support. -
Easy setup and management
Intuitive browser-based tools, mass deployment capabilities, and consistent features across it simplify setup and configuration. -
An eco-friendly solution
Switch optimizes power usage for energy efficiency without compromising performance.
- Cisco Small Business SG300-28P - switch - 28 ports - Managed
- Switch - 28 ports - L3 - Managed
- Enclosure Type
- 1U
- Subtype
- Gigabit Ethernet
- Ports
- 26 x 10/100/1000 + 2 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE
- MAC Address Table Size
- 8000 entries
- Routing Protocol
- Static IPv4 routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
- Layer 3 switching, Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, STP support, RSTP support, MSTP support, TFTP support, ACL support, QoS, Jumbo Frames support, MLD snooping
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 25.7 cm x 4.5 cm
- 4.1 kg
- Localisation
- Chinese (simplified), English, German, French, Italian, Spanish, Japanese / Europe
- Limited lifetime warranty
- Enclosure Type
- Desktop 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- 8000 entries
- Routing Protocol
- Encryption Algorithm
- SSL
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+
- RAM
- 128 MB
- Flash Memory
- 16 MB Flash
- Status Indicators
- Port transmission speed, system, link/activity
- 24 x 1000Base-T RJ-45 PoE , 2 x 1000Base-T RJ-45 , 1 x console DB-9 management , 2 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- Cables Included
- 1 x serial cable
- Rack Mounting Kit
- Included
- UL 60950, CSA 22.2 No. 60950, FCC Part 15 A
- Localisation
- 44 cm
- 25.7 cm
- 4.5 cm
- 4.1 kg
- Limited warranty - replacement - lifetime - response time: next business day
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
