The key to succeeding in today's competitive business environment is investing resources wisely and getting the most value for your dollars. What if you could achieve business-class security and performance in your small business network without paying for advanced network features your network may not need? Now you can with Cisco 200 series smart switch. When you need to share network resources and connect computers, printers, and servers, but low cost is a top priority, Cisco 200 series switch provides the ideal solution.
The business network you need, at an affordable price
The Cisco 200 series is a portfolio of affordable smart switches that combine powerful network performance and reliability with the entry-level managed switch features you need for a business network. -
Simplify setup and management
Cisco 200 series switch is designed to be easy to configure, manage, and troubleshoot, allowing you to focus on your business priorities. -
Gain enhanced features at the right price
Cisco 200 series switch offers essential Layer 2 switch features at a much lower price than advanced managed switches. -
Protect your business investment
Cisco 200 series switch offers the reliable performance, investment protection, and peace of mind you expect from a Cisco switch. -
A powerful foundation for the basic business network
Cisco 200 series smart switch helps you build a business-class network for an affordable price. It provides just the right security, management, and QoS features you need to make the most of your business applications and productivity tools, without the costs or complexity of a managed switch.
- Cisco Small Business Smart SF200-48P - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 24 x 10/100 (PoE) + 24 x 10/100 + 2 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE
- Performance
- Switching capacity: 10.12 Mpps , Forwarding performance (64-byte packet size): 13.6 Gbps
- MAC Address Table Size
- 8000 entries
- Jumbo Frame Support
- Remote Management Protocol
- RMON, HTTP, TFTP
- Layer 2 switching, DHCP support, power over Ethernet (PoE), BOOTP support, VLAN support, IGMP snooping, Syslog support, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, Spanning Tree Protocol (STP) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x
- Power
- AC 120/230 V (50/60 Hz)
- 44 cm x 35 cm x 4.4 cm
- 4.7 kg
- Limited lifetime warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- PoE
- Performance
- 8000 entries
- RMON, HTTP, TFTP
- Encryption Algorithm
- MD5
- Authentication Method
- RADIUS
- RAM
- 128 MB
- Flash Memory
- 16 MB
- Status Indicators
- Port transmission speed, system, PoE, link/activity
- 24 x 100Base-TX RJ-45 , 24 x 100Base-TX RJ-45 PoE , 2 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- Mounting Kit
- Included
- MTBF
- 174,966 hours
- UL 60950, FCC Part 15 A, CSA 22.2
- 44 cm
- 35 cm
- 4.4 cm
- 4.7 kg
- Limited warranty - lifetime , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
