The Cisco Unified IP Phone 7942G is a full-featured IP phone with speakerphone and handset designed for wideband audio. It is intended to meet the needs of needs of transaction-type workers with significant phone traffic. It has two programmable backlit line/feature buttons and four interactive soft keys that guide you through all call features and functions. The phone has a large, 4-bit grayscale graphical LCD that provides features such as date and time, calling party name, calling party number, digits dialed, and presence information. The crisp graphic capability of the display allows for the inclusion of higher value, more visibly rich Extensible Markup Language (XML) applications, and support for localization requiring double-byte Unicode encoding for fonts. A hands-free speakerphone and handset designed for hi-fidelity wideband audio are standard on the Cisco Unified IP Phone 7942G, as is a built-in headset connection and an integrated Ethernet switch.
- Cisco Unified IP Phone 7942G - VoIP phone
- Product Type
- VoIP phone
- Main Features
- Integrated Ethernet switch
- VoIP Protocols
- SCCP, SIP
- Voice Codecs
- G.722, G.729a, G.729ab, G.711u, G.711a, iLBC
- Speakerphone
- Yes (digital duplex)
- Voice Mail Capability
- Call Services
- Voice Mail
- Display
- LCD display - monochrome
- Network Ports Qty
- 2 x Ethernet 10Base-T/100Base-TX
- Body Colour
- Silver, dark grey
- Product Type
- VoIP phone
- Body Colour
- Silver, dark grey
- Body Material
- ABS plastic
Phone Features
- Call Services
- Voice Mail
- Dialer Type
- Keypad
- Dialer Location
- Base
- Conference Call Capability
- Speakerphone
- Menu Operation
- Function Buttons
- Speakerphone button, headset button, menu navigation keys, mute button
- Programmable Buttons Qty
- 2
- Volume Control
- Ringer Control
- Ring Tones
- 24
- Firmware Upgradable
- Additional Functions
- Web browser
IP Telephony
- Main Features
- VoIP
- VoIP Protocols
- SCCP, SIP
- Voice Codecs
- Quality of Service
- IEEE 802.1Q (VLAN), IEEE 802.1p
- IP Address Assignment
- DHCP, static
- Security
- 128 bit AES
- Power Over Ethernet (PoE) Support
- Network Protocols
- TFTP
- Network Ports Qty
- Voice Features
- Echo cancellation (ECN)
- Network Features
- Class 2 PoE
Display
- Display Location
- Base
- Diagonal Size
- 5"
- Display Resolution
- 320 x 222 pixels
- Display Information
- Date, time
- Connections
- Headset jack
- Hearing Aid Compatible
- Placing / Mounting
- Wall-mountable, table-top
Dimensions & Weight (Base)
- 26.7 cm
- 15.2 cm
- 20.3 cm
- 1.6 kg
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
