Cisco Catalyst 2960X-48FPD-L Switch Managed 48 x 10/100/1000
Quicklinx: C8X1WS00 Mfr#: WS-C2960X-48FPD-L
Type: Gigabit Ethernet
Ports: 48
Managed: Yes
POE: PoE+
£7,045.91 ex VAT
£8,455.09 inc VAT
Cisco Catalyst 2960-X series switch is the next generation of the world's most widely deployed access switches. It enables intelligent services such as application visibility; smart operations layer 3 routing and deliver best-in-class energy efficiency with up to 80 percent energy savings.
  • ETHERNET PORT CONFIGURATION
    48 10/100/1000 Gigabit Ethernet ports, two 10 G SFP+ uplink ports
  • POWER
    PoE+ support with a power budget of up to 740W and Perpetual PoE; max of 48 PoE ports (or 24 PoE+ ports)
  • DEVICE MANAGEMENT
    Web UI, over-the-air access via Bluetooth, CLI (command-line interface), SNMP (Simple Network Management Protocol) and RJ-45 or USB console access
  • SECURITY
    802.1X, Switched Port Analyser (SPAN) and Bridge Protocol Data Unit (BPDU) Guard
  • PEACE OF MIND
    Enhanced limited lifetime warranty
Cisco Catalyst 2960X-48FPD-L - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 (PoE+) + 2 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
740 W
Performance
Switching capacity: 216 Gbps , Forwarding performance (64-byte packet size): 130.9 Mpps
Virtual interfaces (VLANs): 1023
Jumbo Frame Support
9216 bytes
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, TFTP, SSH, CLI
Layer 2 switching, DHCP support, PoE, auto-negotiation, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, IDS, IPv6 support, RSTP support, MSTP support, DTP support, PAgP support, TFTP support, ACL support, RADIUS support, SSH support, Jumbo Frames support, MLD snooping, DAI, PoE+, Cisco EnergyWise technology, URPF, UDLD, Rapid PVST+, IPv4 support, SRR, LACP, MAC Address Notification, RSPAN, NetFlow, HSRP support, Energy Efficient Ethernet, MVR, CoS, Cisco FlexStack Plus
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ae, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.1AX
Power Redundancy
Optional
44.5 cm x 36.8 cm x 4.5 cm
5.8 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
740 W
Performance
Jumbo Frame Support
9216 bytes
Max Units In A Stack
8
Authentication Method
Kerberos, Secure Shell (SSH), RADIUS, TACACS+
: 600 MHz
RAM
512 MB
Flash Memory
128 MB
Status Indicators
Port status, port transmission speed, port duplex mode, system, RPS (Redundant Power Supply), PoE, link/activity
48 x 1000Base-T 10Base-T/100Base-TX/1000Base-T - RJ-45 - RJ-45 24 ports (PoE+) / 48 ports (PoE) - 30 W , 1 x console console - RJ-45 - RJ-45 , 1 x mini-USB console - mini-USB Type B - Type B management , 2 x USB Type A , 1 x 1000Base-TX 10Base-T/100Base-TX - RJ-45 - RJ-45 management , 2 x SFP+ - SFP+ uplink
Expansion Slots
1 (total) / 1 (free) x Stacking Module
Internal power supply
Power Redundancy
Optional
Redundant Power System (RPS) connector
MTBF
233,370 hours
CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class A, AS/NZS 60950-1, ICES-003 Class A, RoHS, FCC CFR47 Part 15, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, Directive 2011/65/EU, VCCI Class A, KN24, KN22 Class A, EN 300386
Software Included
Cisco IOS LAN Base
44.5 cm
36.8 cm
4.5 cm
5.8 kg
Limited warranty - advance parts replacement - lifetime - response time: next business day , Technical support - consulting - 90 days
-5 °C
45 °C
10 - 95% (non-condensing)
Min Storage Temperature
-25 °C
Max Storage Temperature
70 °C
Humidity Range Storage
C8X1 Cisco 10GBASE-SR SFP Module In Stock £456.99
C8X1 Cisco 10GBASE-CU SFP+ CABLE 5 METER In Stock £117.91
C8X1 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
C8X1 Cisco AC Power Cord (UK), C13, BS 1363, 2.5m In Stock £40.21
C8X1 Cisco Console Cable 6 ft with USB Type A and mini-B In Stock £83.07
C8X1 Cisco 10GBASE-CU SFP+ Cable 1 Meter In Stock £78.60
C8X1 Cisco 1000BASE-LX/LH SFP Transceiver In Stock £460.42
C8X1 Cisco SFP+ Copper Twinax Cable - SFP+ - SFP+ - 3m In Stock £78.60
C8X1 Cisco SFP+ Transceiver Module In Stock £510.47
C8X1 Cisco AC Power Cord In Stock £46.94
C8X1 Cisco Connectors/Cabinet Power Cord 250 VAC In Stock £22.96
C8X1 Cisco SFP+ Copper Twinax Cable 2m - Brown In Stock £105.73
C8X1 Cisco SFP+ Transceiver Module 10 Gigabit Ethernet 10GBase-LR LC/PC In Stock £1,688.80
Ports: 48
Managed: Yes
POE: PoE+
Brand: Cisco
Price Range Ex VAT: £1500+
