Cisco 890 Series Integrated Services Routers combine Internet access, comprehensive security, and wireless services in a single, secure device that is easy to deploy and manage. The best-in-class Cisco 890 series architecture has been specifically designed to deliver high performance with concurrent services, business continuity, and investment protection for enterprise small branch offices and service provider managed services applications.
Cisco 890 Series Integrated Services Routers are fixed-configuration routers that provide collaborative business solutions for secure voice and data communications to enterprise small branch offices. They are designed to deliver secure broadband, Metro Ethernet, wireless LAN (WLAN) connectivity, and business continuity. The routers also come with powerful management tools, such as the web-based Cisco Configuration Professional configuration management tool, which simplifies setup and deployment. Centralized management capabilities give network managers visibility and control of the network configurations at the remote site.
Secure network connectivity
Cisco 890 series routers deliver high performance with integrated security and threat defense. Network security has become a fundamental building block of any network, and Cisco routers play an important role in embedding security at the customer's access edge. Cisco IOS Content Filtering uses an innovative website caching and rating architecture to deliver the scalability and flexibility of an enterprise-class filtering solution, at a breakthrough price point. This solution is scalable and easy to maintain, ideally suited for small businesses and enterprise small branch offices. Cisco 890 series routers come with a comprehensive security solution that protects organizations' networks from known and new Internet vulnerabilities and attacks, while improving employee productivity. -
Metro Ethernet connectivity
Cisco 890 series routers are ideal for service provider deployments as Metro Ethernet customer premises equipment (CPE). Cisco 892 Integrated Services Routers include two onboard WAN interfaces, one Gigabit Ethernet WAN port, and one Fast Ethernet WAN port to support the high-bandwidth demands of Metro Ethernet deployments. The router also provides failover protection and load balancing. The Cisco 890 Series provides significant value to customers by simplifying deployment of Ethernet WAN services with end-to-end OAM, SLA monitoring and verification, and configuration management, resulting in increased operational efficiency and reduced operating expenses (OpEx). -
High availability
Cisco 890 series routers enable customers to deliver high-performance and high-availability, mission-critical business applications. These capabilities include Virtual Router Redundancy Protocol (VRRP) (RFC 2338), Hot Standby Router Protocol (HSRP), Multigroup HSRP (MHSRP), and dial backup with external modem through a virtual auxiliary port. Cisco 890 series routers are integrated with ISDN BRI for a secondary WAN backup connection. If the primary Ethernet-access WAN is disconnected, the router detects this failure and fails over to the secondary backup WAN. -
Integrated Wireless LAN capability
The Cisco 890 series is ideal for enterprise small branch offices and small businesses that need to be connected to larger enterprise networks. These routers help extend corporate networks to secure remote sites while giving users access to the same applications found in a corporate office. They provide increased reliability for diversity of wireless data, voice, and video applications. When users require WLAN access, visibility and control of network security are even more critical at the remote site. The Cisco 890 series meets this need with a single device that combines integrated 802.11a/g/n capabilities with security features such as Wi-Fi Protected Access (WPA), including authentication with IEEE 802.1X with Cisco Extensible Authentication Protocol (LEAP) and Protected EAP (PEAP), and encryption with WPA Temporal Key Integrity Protocol (TKIP).
- Cisco 892 - router - ISDN - desktop
- Router - ISDN terminal adapter - 8-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 3
- Data Link Protocol
- Ethernet, Fast Ethernet
- Capacity
- IPSec VPN tunnels: 50
- L2TP, IPSec, FTP, DHCP, DNS, L2TPv3, DDNS
- Routing Protocol
- OSPF, RIP-1, RIP-2, BGP, EIGRP, HSRP, VRRP, NHRP, PIM-SM, GRE
- Remote Management Protocol
- Telnet, SNMP 3, HTTP, HTTPS, SSH
- NAT support, VPN support, load balancing, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, traffic shaping, Stateful Packet Inspection (SPI), content filtering, DiffServ support, MAC address filtering, IPv6 support, High Availability, Intrusion Prevention System (IPS), URL filtering, Stateful Failover, Class-Based Weighted Fair Queuing (CBWFQ), Weighted Fair Queuing (WFQ), Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), Link Fragmentation and Interleaving (LFI), Dynamic Multipoint VPN (DMVPN), WAN failover, DHCP server, Virtual Route Forwarding-Lite (VRF-Lite), DNS proxy, Bidirectional Forwarding Detection (BFD)
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x
- Power
- AC 120/230 V (50/60 Hz)
- 32.5 cm x 24.9 cm x 4.4 cm
- 2.5 kg
- Router - 8-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Capacity
- Routing Protocol
- Encryption Algorithm
- LEAP, DES, Triple DES, SSL, PEAP, TKIP, PKI, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- RADIUS, TACACS+
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x, CISPR 24, EN 61000-3-2, EN55022, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN50082-1, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, AS/NZ 3548 Class B, EN 60555-2, FCC CFR47 Part 15, FCC CFR47 Part 15 B, VCCI V-3, EN 300 386
- RAM
- 512 MB (installed) / 768 MB (max)
- Flash Memory
- 256 MB (installed) / 256 MB (max)
- Status Indicators
- Port status, power
Communications
- LAN: 8 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x console - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Management: 1 x auxiliary - RJ-45 , USB 2.0: 2 x 4 pin USB Type A , WAN: 1 x BRI ST
- Power Device
- External power adapter - 60 Watt
- Voltage Required
- OS Provided
- Cisco IOS Advanced IP services
- 32.5 cm
- 24.9 cm
- 4.4 cm
- 2.5 kg
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
