The Cisco 880 series integrated services routers combine Internet access, security and wireless services onto a single, secure device that is simple to use and manage for small businesses and enterprise small branch and teleworkers. The Cisco 880 series delivers features, including firewall, content filtering, VPNs, and WLANs, at broadband speeds to small offices. Easy deployment and centralized management features enable the Cisco 880 series to be deployed by enterprises or service providers in small branch offices or small businesses.
- Cisco 881 Ethernet Security - router - desktop
- Router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet
- Capacity
- IPSec VPN tunnels: 20
- L2TP, IPSec
- Routing Protocol
- OSPF, RIP-1, RIP-2, BGP, EIGRP, HSRP, VRRP, NHRP, GRE
- Remote Management Protocol
- Telnet, SNMP 3, HTTP, HTTPS, SSH
- NAT support, interrupt status port (ISP), VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Stateful Packet Inspection (SPI), content filtering, MAC address filtering, IPv6 support, Stateful Failover, Class-Based Weighted Fair Queuing (CBWFQ), Weighted Fair Queuing (WFQ), Access Control List (ACL) support, Quality of Service (QoS), Dynamic Multipoint VPN (DMVPN), DHCP server, Virtual Route Forwarding-Lite (VRF-Lite), DNS proxy
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x
- Power
- AC 120/230 V (50/60 Hz)
- 32.5 cm x 24.9 cm x 4.4 cm
- Enclosure Type
- Desktop
- Connectivity Technology
- Wired
- Capacity
- L2TP, IPSec
- Routing Protocol
- Encryption Algorithm
- LEAP, DES, Triple DES, MD5, TLS, PEAP, TTLS, TKIP, WPA, WPA2, WPA-PSK, PKI, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- RADIUS, TACACS+
- IEEE 802.1D, IEEE 802.1Q, IEEE 802.1x, VCCI-II, EN55024, CSA 22.2 No. 60950, EN55022 Class B, AS/NZ 3548 Class B, AS/NZS 60950-1, CS-03, EN 60555-2, UL 60950-1, IEC 60950-1
- RAM
- 256 MB (installed) / 768 MB (max) - DDR2 SDRAM - SO-DIMM 200-pin
- Flash Memory
- 128 MB
- Status Indicators
- Port status, power
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , Management: 1 x console - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x 4 pin USB Type A
- Expansion Slots
- 1 (total) / 1 (free) x SO-DIMM 200-pin
- Power Device
- External power adapter - 60 Watt
- Voltage Required
- OS Provided
- Cisco IOS Advanced IP services
- 32.5 cm
- 24.9 cm
- 4.4 cm
- 0 °C
- 40 °C
- 10 - 85%
