Cisco 8-Port IP Telephony Gateway
Quicklinx: 7TH3WS00 Mfr#: SPA8000-G5
The Cisco SPA8000 8-Port IP Telephony Gateway is a full-featured analog telephone adapter (ATA) for small businesses, providing enhanced communication services via a broadband connection to the Internet.
The Cisco SPA8000 features eight RJ-11 FXS ports to connect analog telephones to IP-based data networks and includes a single multiport RJ-21 50-pin connector, offering an alternative connection choice when deploying the telephony gateway in varied environments. The device also has one 10/100BASE-T RJ-45 Ethernet interface to connect to either a router or a multilayer switch.
Solid in design, the Cisco SPA8000 is an affordable solution that is ideally suited for use in business and consumer voice over IP (VoIP) service offerings, including call centers and multidwelling environments. Customers can protect and extend their investment by continuing to use their existing analog telephones and teleconferencing equipment.
Installed by the end user and remotely provisioned, configured, and maintained by the service provider, each Cisco SPA8000 converts voice traffic into data packets for transmission over an IP network and uses common standards for voice and data networking for reliable voice and fax operation.
  • Toll-quality voice and carrier-grade feature support
    The Cisco SPA8000 delivers clear, high-quality voice communication in diverse network conditions. Excellent voice quality in a demanding IP network is achieved via the advanced implementation of standard voice coding algorithms. The SPA8000 is interoperable with common telephony equipment such as voicemail, fax, private branch exchange (PBX), and interactive voice response systems.
  • Large-scale deployment and management
    The Cisco SPA8000 enables service providers to provide customized services to their subscribers. It can be remotely provisioned and supports dynamic, in-service software upgrades. A highly secure profile upload saves providers the time and expense of managing and preconfiguring or reconfiguring customer premises equipment (CPE).
  • Ironclad security
    Cisco understands that security for both end users and service providers is a fundamental requirement for a solid, carrier-grade telephony service. The Cisco SPA8000 supports highly secure, encryption-based methods for communication, provisioning, and servicing.
Cisco Small Business Pro SPA8000 8-port IP Telephony Gateway - VoIP phone adapter
VoIP phone adapter
External
Ethernet, Fast Ethernet
VoIP Protocols
SIP v2
Telephony Interfaces
8 phone (FXS)
22 cm x 17 cm x 3.3 cm
1.3 kg
VoIP phone adapter
22 cm
17 cm
3.3 cm
1.3 kg
External
Wired
Network / Transport Protocol
TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE
Remote Management Protocol
HTTP, HTTPS
DHCP support, NAT support, ARP support, Syslog support, DiffServ support, VPN passthrough, SNTP support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS)
Encryption Algorithm
MD5, TLS, PEAP, TTLS, 256-bit AES
Authentication Method
Extensible Authentication Protocol (EAP)
IEEE 802.3, IEEE 802.1p
IP Telephony
VoIP Protocols
SIP v2
Voice Codecs
G.711, G.723.1, G.729a, G.726, T.38
8 phone (FXS)
IP Telephony Features
Comfort noise generation (CNG), echo cancellation (G.168), call forwarding, Caller ID, call waiting, echo cancellation (G.165), call transfer
8 x modem - RJ-11 , 1 x phone line , 1 x 100Base-TX - RJ-45 (WAN)
1 x network cable
UL, C-Tick, ICES-003, FCC Part 15 B, RoHS
External power adapter
45 °C
10 - 90%
