Cisco 100 series switch delivers powerful network performance and flexibility for small business networks, without the complexity. With no installation software and nothing to configure, you get an affordable, reliable network that just works, right out of the box.
High-performance capabilities
With powerful network performance at an affordable price, you can give your network a boost of speed and capacity to support bandwidth-intensive applications. -
Support for advanced technologies
Built-in quality of service (QoS) intelligence helps maintain consistent network performance and keeps your applications running smoothly. -
An eco-friendly solution
Optimizes power usage to be energy efficient without compromising performance. -
Affordability
Designed specifically for small businesses that need a basic network with automated features that get you up running in minutes. -
Ease of use
Works right out of the box, there's no software to install and nothing to configure.
- Cisco Small Business SF 102-24 - switch - 24 ports - unmanaged - rack-mountable
- Switch - 24 ports - unmanaged
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- 24 x 10/100 + 2 x combo Gigabit SFP
- Performance
- Switching capacity: 8.8 Gbps , Forwarding performance (64-byte packet size): 6.5 Mpps
- Flow control, Layer 2 switching, auto-negotiation, auto-uplink (auto MDI/MDI-X), Weighted Round Robin (WRR) queuing, Quality of Service (QoS), fanless
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
- Power
- AC 120/230 V (50 - 60 Hz)
- 44.1 cm x 20.3 cm x 4.4 cm
- 2 kg
- System Requirements
- Linux, Apple MacOS X, Microsoft Windows
- Localisation
- United Kingdom
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Fast Ethernet
- Ports
- Performance
- Status Indicators
- System, link/activity
- 24 x 100Base-TX RJ-45 , 2 x 1000Base-T RJ-45 , 2 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- CSA, UL, UL 60950, CSA C22.2, FCC CFR47 Part 15, FCC Part 15 A
- Localisation
- United Kingdom
- OS Required
- 44.1 cm
- 20.3 cm
- 4.4 cm
- 2 kg
- Limited warranty - replacement - lifetime , Limited warranty - power supply and fans - 1 year , Technical support - phone consulting - 1 year , New releases update - 1 year
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
