Eliminate compromise on voice quality or features for phone and fax capabilities associated with Internet voice over IP (VoIP) service. Cisco VoIP solutions provide the quality, peace of mind, and investment protection at an affordable price.
The Cisco SPA112 2 Port Adapter enables high-quality VoIP service with a comprehensive feature set through a broadband Internet connection. Easy to install and use, it works over an IP network to connect analog phones and fax machines to a VoIP service provider and provides support for additional LAN connections.
The Cisco SPA112 includes two standard telephone ports to connect existing analog phones or fax machines to a VoIP service provider. The phone line can be configured independently. With the Cisco SPA112, users can protect and extend their investment in their existing analog telephones, conference speakerphones, and fax machines as well as control their migration to IP voice with an extremely affordable, reliable solution.
Compact in design and compatible with international voice and data standards, the Cisco SPA112 can be used with residential, home-office, and small business VoIP service offerings, including full-featured hosted or open source IP PBX environments. This easy-to-use solution delivers advanced features to better connect employees and serve customers, all on a highly secure Cisco network.
Please note that this device is NOT compatible with either BT Cloud Voice and/or BT Cloud Phone services. For further information on how to order these, please contact the respective helpdesks: BT Cloud Voice = 0800-3890537 and BT Cloud Phone = 0800-389 0598.
Toll-quality voice and carrier-class feature support
The Cisco SPA112 delivers clear, high-quality voice communication under a variety of network conditions. Excellent voice quality in challenging, changeable IP network environments is made possible through the advanced implementation of standard voice coding algorithms. -
Large-scale deployment and management
The Cisco SPA112 enables service providers to provide customized services to their subscribers. It can be remotely provisioned and supports dynamic, in-service software upgrades. A highly secure profile upload saves providers the time and expense of managing and preconfiguring or reconfiguring customer premises equipment (CPE) for deployment. -
Outstanding security
The Cisco SPA112 supports highly secure, encryption-based methods for communication, provisioning, and servicing. -
Compact size
Designed for small spaces, the Cisco SPA112 can be installed as a desktop unit or mounted on a wall. -
Comprehensive feature set
The standards-based Cisco SPA112 is compatible with Internet VoIP provider features such as Caller ID, call waiting, voicemail, call forwarding, distinctive ring, and much more to provide a complete, affordable, and highly reliable solution for high-quality VoIP. -
Easy installation and changes
The web-based configuration utility enables quick deployment and easy changes.
- Cisco Small Business SPA112 - VoIP phone adapter
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet
- VoIP Protocols
- SIP, SIP v2, RTCP, RTP, SRTP
- Telephony Interfaces
- 2 phone (FXS)
- Power
- AC 120/230 V (50/60 Hz)
- 10.1 cm x 10.1 cm x 2.8 cm
- 153 g
- 1-year warranty
- 10.1 cm
- 10.1 cm
- 2.8 cm
- 153 g
- Form Factor
- External
- Connectivity Technology
- Wired
- TCP/IP, UDP/IP, ICMP/IP, ARP, DNS
- Remote Management Protocol
- HTTP, HTTPS, TFTP, TR-069
- Status Indicators
- Port status, power
- NAT support, ARP support, VLAN support, SNTP support, Trivial File Transfer Protocol (TFTP) support, IPv4 support, DHCP client
- Encryption Algorithm
- MD5, TLS, 256-bit AES
- IEEE 802.3, IEEE 802.1p
IP Telephony
- VoIP Protocols
- Voice Codecs
- G.711, G.728, G.729a
- 2 phone (FXS)
- IP Telephony Features
- Voice activity detection (VAD)
- 2 x modem - RJ-11 , 1 x 100Base-TX - RJ-45 (WAN)
- Cables Included
- 1 x network cable - 1.8 m
- UL, ICES-003, FCC Part 15 B, RoHS, A-Tick
- Power Device
- External power adapter
- Voltage Required
- Limited warranty - 1 year
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
