Cisco 2.4 AND 5 GHZ LIGHTNING ARREST
Quicklinx: 4DNMWS00 Mfr#: AIR-ACC245LA-R
Overvoltage transients can be created through lightning static discharges, switch processes, direct contact with power lines, or through earth currents. The Cisco Aironet AIR-ACC245LA-R Lightning Arrestor limits the amplitude and duration of disturbing interference voltages and improves the overvoltage resistance of in-line equipment, systems, and components. A lightning arrestor installed according to these mounting instructions balances the voltage potential, thus preventing inductive interference to parallel signal lines within the protected system.
The Cisco Aironet AIR-ACC245LA-R Lightning Arrestor is designed for use with Cisco Aironet access points and bridges but can be used Cisco Aironet radio device that utilizes an RP-TNC connector.
Cisco Aironet Lightning Arrestor - lightning arrester
Lightning arrester
0.2 kg
Aironet 1200, 1220, 1230, 1230AG, 1231, 1231G, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
Lightning arrester
0.2 kg
Cabling & Wiring
Connector Provided
1 x TNC
-40 °C
85 °C
Cisco Aironet 1200, 1220, 1230, 1230AG, 1231, 1231G, 1232AG, 1242AG, 1242G, 1250 Modular Unified Access Point Platform, 1252AG, 1252AG Standalone Access Point, 1252AG Unified Access Point, 1252G, 1252G Unfied Access Point, 1260 Series Access Point (Controller-based)
