GENTIX a mouse to hold on to! This exceptional design with striking blue light on the sides and the scroll wheel is truly eye-catching on any work surface. The slip-proof sides made from solid rubber ensure smooth, accurate cursor control even in hectic situations. The GENTIX mouse can be connected quickly and easily to any Notebook, PC or Mac via the USB connection.
- Reliable corded mouse with three keys and optical sensor
- Striking blue light on sides and scroll wheel
- Rubber side surfaces and rubber scroll wheel offer improved grip
- Symmetrical design - suitable for left and right-handed users
- High-resolution optical sensor with 1000 dpi resolution for precise and flowing cursor control
- 1.8 m cable with USB connection for use on the laptop and PC
- CHERRY GENTIX Illuminated - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- Orientation
- Right and left-handed
- 6.9 cm x 11.1 cm x 3.5 cm
- 120 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Scrolling wheel, rubber side grips
- Cables Included
- 1 x USB cable - integrated - 1.8 m
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Orientation
- 6.9 cm
- 11.1 cm
- 3.5 cm
- 120 g
- Black
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- 1000 dpi
- 1 x USB - 4 pin USB Type A
- Cables Included
- Plug and Play, C-Tick, FCC, cTUVus, KC
- Limited warranty - 2 years , Extended warranty - 1 year
- 0 °C
- 40 °C
