Casio XJ-V100W-UJ 3000LM WXGA DLP Technology Projector
Quicklinx: C4DKWS00 Mfr#: XJ-V100W-UJ
The XJ-V100W uses the cost-effective, environmentally friendly Casio laser and LED hybrid light source, boasting a brightness of 3000 ANSI lumens. It offers outstanding low total cost of ownership for high-quality, impactful presentations.
  • Incredible light source
    This projector is able to function without the use of toxic mercury and greatly reduce power consumption.
  • A durable light source
    Thanks to the use of mercury-free lighting technology, the XJ-V100W is able to function for extended periods without replacing the lamp.
  • Outstanding color rendition
    The incredible laser and LED hybrid light source guarantees clear and brilliant color reproduction for projectors - even in daylight.
  • Kind to the environment
    The light source fitted in the XJ-V100W projector is mercury-free and environmentally friendly.
  • Great performance - minimal consumption
    This projector delivers brilliant results with low power consumption.
  • Connection via HDMI
    Thanks to the existing HDMI interface, the projector can be easily connected to external components, such as a suitably equipped laptop.
  • Fit for continuous use
    Thanks to the special light source and DLP technology, this projector is suitable for continuous use.
Casio Core XJ-V100W - DLP projector - white
DLP projector
White
Brightness
3000 ANSI lumens
Contrast Ratio
20000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Video Input
RGB, component video
Video Modes
480p, 1080p
135 Watt
29.9 cm x 29.9 cm x 9.7 cm
3.5 kg
DLP projector
Enclosure Colour
White
Projector
Brightness
3000 ANSI lumens
Contrast Ratio
20000:1
Image Size
89 cm - 762 cm
Projection Distance
0.83 m
Throw Ratio
1.32 - 1.93:1
Resolution
WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
16:10
Colour Support
Bulb type
Laser/LED
Bulb life cycle
Up to 20000 hour(s)
Controls & Adjustments
Keystone correction
Freeze frame, Direct Power On, Direct Power Off, upgradable firmware, Intelligent Brightness Control, rear projection, instant on/off
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.5x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
HDMI, RGB
Video Modes
480p, 1080p
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - Micro-USB Type B , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management)
2 x AAA batteries, wireless remote control
Security Features
Password protection
135 Watt
Power Consumption Stand by
0.23 Watt
29.9 cm
29.9 cm
9.7 cm
3.5 kg
5 °C
35 °C
Sound Emission
35 dB
