Canon i-SENSYS MF542x Mono Laser Multifunction Printer
Quicklinx: FRZHWS00 Mfr#: 3513C008
£493.79 ex VAT
£592.54 inc VAT
Save space with a compact design boasting print, scan and copy functionality, a perfect fit for productive businesses in need of a high-performance black and white laser printer.
Canon i-SENSYS MF542x in More Detail
The Canon i-SENSYS MF542x is a fast and versatile A4 mono multifunction printer that’s ideal for busy small businesses who need a reliable laser printer to meet the demands of their heavy workloads. Boasting ultra-fast print speeds and a range of versatile connectivity options, it’s ready to take your team’s productivity to the next level.
Ultra-fast printing
The Canon i-SENSYS MF542x is capable of printing at speeds of up to 43ppm in A4 and comes with a large capacity 550 sheet paper tray, making it ideal for larger print runs. Meanwhile, automatic double-sided printing and single-pass double-sided scanning make printing more efficient than ever, helping you get through your workload in less time.
Customisable controls
The Application Library allows you to tailor the on-screen controls and provides one-touch access to frequently used functions, like printing a saved form or scanning to email. What’s more, the Universal Login Manager (ULM) offers a variety of personalisation options and provides control over user printing rights.
Versatile mobile connectivity
The Canon i-SENSYS MF542x is truly designed for modern working schedules and offers a range of versatile connectivity options that make it easy to print from any device. There’s USB, Network, Wireless and Wi-Fi Direct connectivity, with full support for AirPrint (iOS) and Mopria (Android).
Advanced security
The secure PIN document release function provides control over confidential documents, while the Universal Login Manager (ULM) offers further privacy controls via user authentication.
High-quality printing at an affordable price
Whether you’re printing copies of an internal document or a long sales presentation, you can count on high-quality results at an affordable price. Genuine Canon toner cartridges such as the 056H High Capacity Black Toner Cartridge can even produce up to 21,000 pages* before needing a replacement.
Compact design
The i-SENSYS MF542x wraps high performance and advanced functionality into a sleek, compact body – perfect for those who are short on space.
Canon i-SENSYS MF542x - multifunction printer - B/W
Multifunction printer
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
150000 pages
Recommended Monthly Volume
2000 - 7500 pages
Max Copying Speed
Up to 43 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 43 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Original Size
105 x 128 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, postcards
Standard Media Capacity
650 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, scan to SMB, scan to PC
AC 230 V (50/60Hz)
48 cm x 46.4 cm x 45.2 cm
19.8 kg
2-year Limited Warranty
Printer Fonts
PCL x 93 , PostScript x 136
Printing Technology
Laser - monochrome
150000 pages
2000 - 7500 pages
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Copying Speed
Up to 43 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, photo, text and photo
Automatic Duplexing
Copying Features
2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
Max Printing Speed
Up to 43 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PDF, TIFF, UFRII, JPEG
Automatic Duplexing
First Print Out Time B/W
5.7 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Document & Media Handling
Min Original Size
105 x 128 mm
Max Original Size
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 105 x 128 mm
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
199 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
650 sheets
100 sheets
150 sheets
DSDF - 50 sheets size: 105 x 128 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 105 g/m² , Paper cassette - 550 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Bypass tray - 100 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 199 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 43 ppm (A4) - B/W , Printing: up to 65.2 ppm (A5) - B/W , Printing: up to 36 ipm (A4) - B/W duplex , Copying: up to 43 ppm (A4) - B/W , Copying: up to 34.4 ipm - B/W duplex , Scanning: up to 38 ipm - B/W , Scanning: up to 13 ipm - colour , Scanning: up to 70 ipm - B/W duplex , Scanning: up to 26 ipm - colour duplex
1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Security Protocols & Features
Secure Print, SSL, Apple Bonjour, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, PING, ARP, MAC address filtering, SNMP 3
Operating System Support
Linux, MS Windows 7, MS Windows Server 2008, MS Windows Server 2008 R2, MS Windows Server 2012, Android, iOS, Windows 8.1, MS Windows Server 2012 R2, Windows 10, Apple Mac OS X 10.9.5 or later, MS Windows Server 2016, macOS 10.14, MS Windows Server 2019
Software Included
Drivers & Utilities, iW Management Console, uniFLOW online, uniFLOW online Express
AC 230 V (50/60Hz)
1430 Watt
Power Consumption Standby
13.6 Watt
Power Consumption Sleep
0.9 Watt
Warm-Up Time
14 sec
Consumables Included
1 x toner cartridge (black) - up to 5100 pages - Canon 056L
48 cm
46.4 cm
45.2 cm
19.8 kg
Sound Emission
24 dB (idle) / 54 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
