The 0.5u patch panel saves space by reducing the size of a standard patch panel by half and allowing you to use two panels in place of one.
The patch panel comes with instructions for fitting T568B wiring but can also be used for T568A.
- Cat 6
- 24 Port
- Labelled for T568B standard
- Cables Direct UT-8824COM6 - patch panel - 0.5U
- Product Type
- Patch panel - CAT 6 - RJ-45 X 24
- Package Content
- Cable ties (10 pcs), 2 cage bolts
- Port Qty
- 24 ports
- Height (Rack Units)
- 0.5U
- Wiring Scheme
- T568B
- 1-year warranty
- Product Type
- Package Content
- 0.5U
Cabling & Wiring
- Port Qty
- 24 ports
- Wiring Scheme
- T568B
- Connector Provided
- 24 x RJ-45 female
- Limited warranty - 1 year
