C2G 3m Ultima™ HD15 Male to RCA HDTV Component Video Breakout Cable
Quicklinx: 67VXWS00 Mfr#: 80357
Ultima HDTV Video Cables from C2G are specifically designed for digital and next generation, high definition analog video applications. The Ultima HDTV Video Cables are constructed from three individually shielded, 75-Ohm coax cables, which provide a performance connection that maximizes color and image. The Ultima HDTV Video Cable meets the rigid standards of everyday use.
C2G Ultima HDTV Component Video Breakout Cable - video cable - component video - 3 m
Cable
Video cable - component video
Shielded
Length
3 m
Connector
HD-15 (VGA) - male
Connector (Second End)
3 x RCA - male
Moulded, thumbscrews
Cable Type
Video cable
Interface Supported
Component video
Shielded
Shielding Material
Foil with copper braid
Impedance
75 Ohm
Length
3 m
Plated Connector
Gold
Connector
3 x RCA - male
RoHS
Limited warranty - lifetime
