Digital Visual Interface (DVI) is the standard interface for high-performance connection between desktop PCs and flat panel displays, CRT displays, projectors, and HDTV. This analogue video cable is fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). Three analogue 30 AWG coaxial lines enable high speed analogue transmission
- C2G VGA cable - 1 m
- VGA cable
- Colour-coded connectors
- Length
- 1 m
- Connector
- DVI-A - male
- Connector (Second End)
- HD-15 (VGA) - male
- PC 99, RoHS
- VGA cable
- American Wire Gauge (AWG)
- 28/30
- Plated Connector
- Gold
- Length
- 1 m
- Connector
- 12+5 pin analogue DVI - male
- 15 pin HD D-Sub (HD-15) - male
- PC 99, RoHS
