3.5mm stereo audio cables from C2G are specifically designed for quality computer audio applications. The 3.5mm cable connects the PC sound card, portable CD player or any mini-stereo audio device with 3.5mm jacks to multimedia speakers. The cable features two 29-gauge stranded conductors and a drain wire, which are tinned to resist oxidation.
- C2G audio cable - 10 m
- Cable
- Audio cable
- Technology
- Shielded
- Length
- 10 m
- Connector
- Mini-phone stereo 3.5 mm - male
- Connector (Second End)
- Colour-coded connectors, moulded
- Cable Type
- Audio cable
- Technology
- Shielded
- Shielding Material
- Foil
- Length
- 10 m
- Plated Connector
- Nickel
- Connector
- RoHS
