Buffalo's new AirStation Dual Band 11ac Wireless Gigabit router (WZR-1166DHP-EU) brings a new and versatile dual band solution with fast transfer speeds and beamforming technology. The WZR-1166DHP-EU is primed and ready-to-go with transfer speeds of up to 866 MBps in the 5GHz spectrum and 300Mbps on the 2.4GHz bandwidth. The 5GHz band is ideal for faster, uninterrupted HD video streaming and concurrent Internet access for new mobile phones, tablets, and laptops. And your other devices will also benefit from the new simultaneous fast transfer speeds in the 2.4GHz bandwidth.
Buffalo's new AirStation uses beamforming technologies to remarkably improve your wireless connection. Beamforming recognizes the devices using wireless and focuses the signal directly to them. And once focused, your wireless signal will have better ability to reach around corners and through walls, helping to eliminate or reduce previous performance obstacles.
In addition to all of this, the AirStation Dual Band 11ac Wireless Gigabit router comes with parental control by Symantec. Upgrade your existing wireless connection to provide greater coverage, beamforming, fast transfer speeds - all whilst protecting your family, Buffalo's new AirStation is the next generation of wireless connectivity.
Make your home network extreme
AirStation Extreme offers a class of features, above and beyond the traditional home router. Experience enhanced coverage, get high speed gigabit wired connections, connect a printer to the network, add shared storage, stream your favorite HD multimedia, game lag-free and let your family surf the web worry free with Norton ConnectSafe web filtering and parental control by Symantec. -
Dual band
Offering simultaneous wireless operation, AirStation Extreme AC 1200 is perfect for streaming HD movies, music and emailing from multiple devices at the same time. -
Gigabit Ethernet
Maximize your wireless network speed with gigabit Ethernet connections that keep your data moving at lightning speed. -
Beamforming technology
Beamforming technology optimizes signal energy for enhanced operation with devices that also support the technology. Beamforming creates a more direct wireless signal as it specifically targets supported connected devices, such as the latest MacBook Air, the Samsung Galaxy S4 and the HTC One M7, boosting performance and range even more to deliver a reliable, high speed wireless connection for bandwidth intensive activities. -
Backward compatible
Easily upgrade your network from previous wireless standards, and maintain compatibility with existing adapters and devices. AirStation Extreme AC 1200 offers extreme performance and greater coverage. -
Easy setup
AirStation Extreme AC 1200 Gigabit dual band wireless router features an easy to use, step by step wizard that guides you through configuration from start to finish. Within moments of opening the box, you'll have a secure wireless home network. -
Wireless bridge
Configure two or more AirStation Extreme AC 1200 devices to act as a standalone wireless bridge. Create a permanent, high-speed wireless link capable of high speeds and wirelessly extend the range of your network. -
QoS
Automatically prioritize your media and entertainment traffic for uninterrupted streaming and lag-free gaming. Best in class features and support for multiple video, audio, gaming, voice and data services provides unharnessed potential for streaming and entertainment possibilities. -
Extreme range
Highpower technology offers optimized antennas and integrated power amplifiers to notably boost signal strength for outstanding range and coverage. -
Symantec Parental Control
This added level of security easily filters unsafe and restricted content for worry free web surfing the whole family can enjoy. -
Wireless security
AirStation Extreme AC 1200 offers the best security standards available, featuring multi-level wireless encryption options to prevent unauthorized access and protect your important data.
- BUFFALO AirStation WZR-1166DHP - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 866 Mbps
- NAT support, auto-uplink (auto MDI/MDI-X), packet filtering, Intrusion Detection System (IDS), print server, MAC address filtering, VPN passthrough, parental control, Airstation OneTouch Secure System (AOSS), MIMO technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), port forwarding, Stateful Packet Inspection Firewall (SPIF), Direct Sequence Spread Spectrum (DSSS)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
- Power
- AC 120/230 V (50/60 Hz)
- 3.4 cm x 18.3 cm x 21.2 cm
- 593 g
- System Requirements
- Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Apple MacOS X 10.4 - 10.8
- 3-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 866 Mbps
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK
- Authentication Method
- Radio Service Set ID (SSID)
Line Properties
- Line Coding Format
- CCK, OFDM
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x 9 pin USB Type A
Aerial
- Aerial
- Internal
- Antenna Qty
- 4
- Power Device
- External power adapter
- Voltage Required
- 15.1 Watt
- OS Required
- 3.4 cm
- 18.3 cm
- 21.2 cm
- 593 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
