Buffalo MiniStation USB 3.0 3TB BK Shock Proof
Quicklinx: CK0JWS00 Mfr#: HD-PNF3.0U3GB-EU
Select:
  • 3TB
Buffalo’s MiniStation™ Safe (HD-PNFU3 series) is a slim, SuperSpeed USB 3.0, portable hard drive that comes in a patented shock-proof chassis and features Buffalo’s new Lock-and-Go feature – thereby protecting your data in two important ways!
  • Lock and go
    Buffalo gave the HD-PNFU3 a sleek design with an attractive matte finish and Buffalo's shock-proof chassis.
  • A small, attractive, and secure package
    Buffalo's MiniStation Safe occupies minimal space and offers USB 3.0 bus-powered mobile storage for your data and for your on-the-go lifestyle. It works with PC and Mac, so you can access your files from whichever computer you are on, even while on the go.
BUFFALO MiniStation Safe (HD-PNFU3 series) - hard drive - 3 TB - USB 3.0
Hard drive - external (portable)
3 TB
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Shock resistant, Bus Powered by USB, software encryption, power management support, Lock-and-Go Security, 256-bit AES, 128-bit AES
Power Source
USB bus
Enclosure Colour
79.5 mm x 115 mm x 21.5 mm
240 g
3 TB
USB 3.0
79.5 mm
115 mm
21.5 mm
240 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Power Source
USB bus
Software Included
SecureLockMobile, Buffalo Tools eco Manager
Microsoft Windows Vista, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 or later, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10
1 x USB 3.0 cable
Plug and Play
Enclosure Colour
5 °C
35 °C
20 - 80% (non-condensing)
