Buffalo's TeraStation Duo is the ideal choice for businesses or demanding users looking to implement a cost effective RAID based Network Attached Storage solution. As the TeraStation III's little cousin, the TeraStation Duo is a dual drive unit that includes all firmware features presently found in the Buffalo lineup of NAS products. In contrast to the TeraStation III 4-drive product, the TeraStation Duo supports RAID 0 and RAID 1 in addition to a simple JBOD configuration. Especially, business oriented features, such Active Directory support, DFS support, disk quota support, a share level replication feature and port trunking make the TeraStation Duo a top choice for small to medium sized businesses. Hardware features like hot swap and dual Ethernet ports add to the list of new features. Reliability and performance are again the key design criteria for the TeraStaion Duo. A heavy-duty power supply and oversized cooling system, as well as vastly improved CPU speed guarantee excellent and reliable performance. It is the clear choice for those users who desire reliability and robust features at an affordable price.
- BUFFALO TeraStation Duo TS-WX2.0TL/R1 - NAS server - 2 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 2 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 17 cm x 17 cm x 23 cm
- 4.5 kg ()
- Storage Controller
- RAID SATA 3Gb/s RAID 0, 1, JBOD
- Hard Drive
- 2 x 1 TB SATA 3Gb/s
- Networking
- Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
- Power
- AC 230V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 2 TB
- 17 cm
- 17 cm
- 23 cm
- 4.5 kg ()
- Built-in Devices
- Status LCD, print server
Storage Controller
- RAID - internal
- Interface Type
- SATA 3Gb/s
- Supported Devices
- Hard drive, disk array (RAID)
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 1 TB
- Interface Type
- SATA 3Gb/s
- Spindle Speed
- 7200 rpm
- Data Link Protocol
- TCP/IP, NTP, FTP, SMB
- Remote Management Protocol
- HTTP
- 128-bit encryption, BitTorrent Client
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
- Expansion Bays
- 2 (total) / 0 (free) x internal
- 2 x USB 2.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45 , 1 x serial RS-232
- Power Device
- Internal power supply
- Voltage Required
- 47 Watt
- Software Included
- NovaBACKUP Business Essentials
- OS Required
- Limited warranty - 3 years
- 0 °C
- 35 °C
- 20 - 80%
