Your basket is empty
Buffalo 2TB DriveStation USB 2.0 Desktop Hard Drive
Sale! Was £87.49
Quicklinx: 7GJWWS00 Mfr#: HD-LB2.0TU2-UK
Form Factor: 3.5"
Capacity: 2TB
Interface: Hi-Speed USB
67 in stock
£54.16 ex VAT
£64.99 inc VAT
Delivery from £0.80
Buffalo's DriveStation USB 2.0 Hard Drive HD-LBU2 is an easy to use external hard drive to add additional external storage to any device using a USB port. The DriveStation features a sleek, black glossy chassis that can be positioned vertically or horizontally, adapting to the location it is used in for an efficient use of space.
Get more storage instantly by simply plugging in Buffalo's DriveStation™ USB 2.0 Hard Drive HD-LBU2 to a PC or Mac via a USB port. The Buffalo DriveStation™ is a quiet external hard drive in a black glossy chassis that looks stylishly sleek whether you place it upright or flat. Its adaptive design allows efficient use of space.
Auto functions
The DriveStation™'s auto installation and auto power on/off features make it easy to use, and provide an economical solution where you can quickly store, access, and transfer files, digital images, documents, and backups.
  • Compatible Interfaces: USB 2.0 Interface - connects to USB on any PC or Mac
  • Pre-formatted drive: Ready to use, anytime
  • Connect and go: Easy to use and setup, simply plug it into the USB and play; no drivers required
  • USB Interface: Standard Compliance USB 2.0, Connector Type USB Type B, Number of Ports1, Data Tansfer Rates Max. 480Mbps (USB 2.0 Mode)
  • Dimensions (WxHxD) 38.7 x 122.6 x 189mm
  • Weight 950g
  • OS SupportWindows®7 (32bit, 64bit), Windows® Vista™(32bit, 64bit), Windows® XP, Mac OS 10.4 or later
BUFFALO DriveStation hard drive - 2 TB - USB 2.0
Hard drive - external ( desktop )
2 TB
USB 2.0
Power Source
Included AC adapter
Enclosure Colour
Glossy black
3.9 cm x 18.9 cm x 12.3 cm
0.95 kg
United Kingdom
2 years warranty
2 TB
USB 2.0
Internal Drive Interface
Serial ATA
3.9 cm
18.9 cm
12.3 cm
0.95 kg
Performance
Max Data Transfer Rate
480 MB/s
Expansion & Connectivity
1 x USB 2.0 - mini-USB Type B
Power Source
Included AC adapter
Power supply
AC 120/230 V ( 50/60 Hz )
Power Consumption (Active)
12 Watt
Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits)
Enclosure Colour
Glossy black
United Kingdom
2 years warranty
Service & Support Details
5 °C
35 °C
20 - 80% (non-condensing)
Resources
The following resources are available for the Buffalo 2TB DriveStation USB 2.0 Desktop Hard Drive
Form Factor: 3.5"
Capacity: 2TB
Brand: Buffalo
Price Range Ex VAT: 50 - 100
