Works with any Broadband provider
BT's Wi-Fi Home Hotspot 500 Add-on has been designed to work with any service provider to make sure everyone can make the most of their Broadband around their home.
What does BT’s Wi-Fi Home Hotspot 500 Kit give you?
Connect any wired or wireless device to your home broadband anywhere in your home with our powerline technology and enjoy the full broadband experience.
Plug & Play - Easy to set-up and install, just instant access to your broadband anywhere in your home!
Everyone loves to be online; and why should you settle for anything other than the complete broadband experience? With BT's Wi-Fi Home Hotspot 500 Add-on, you are able to connect any wired or wireless devices wherever and whenever you like.
With up to 500 Mbps for smooth HD/3D streaming, online gaming or faster downloads, BT's Wi-Fi Home Hotspot 500 Add-on supports all your online needs.
Simple to use
BT's Wi-Fi Home Hotspot 500 Add-on is easy to use. Simply plug into your wall socket, connect to your existing Broadband Extender or powerline network, and you are ready to enjoy a complete broadband experience.
Make the most of your Broadband
BT's Wi-Fi Home Hotspot 500 Add-on offers a solution to a number of your broadband problems. Be it connecting a Smart TV in a different room to your router, generating Wi-Fi where your router doesn't reach or high speed streaming throughout your home, BT's Wi-Fi Home Hotspot 500 Add-on can be used to help make the most of your Broadband at home.
Compatible with other technologies
BT's Wi-Fi Home Hotspot 500 Add-on works seamlessly with all other BT Broadband Extender products to create your new home network. It is also completely compatible with other AV HomePlug powerlines so you can integrate it with an existing Powerline network. The Wi-Fi Home Hotspot 500 Kit utilises HomePlug AV500 Powerline and N300 wireless technologies and can be fully integrated with an existing AV200 network in your home.
Better for the environment
Eco credentials come as standard with built-in power saving and fully recyclable packaging.
Not the right Broadband Extender for you?
BT has a whole range of Broadband Extenders to meet your requirements. Whether you don't want to lose a socket, need to connect multiple devices or prefer to connect wirelessly, BT has the solution.
Please note: This is add-on product to extend your Wi-Fi reach when used with the BT Wi-Fi Hotspot 500 Kit (9BRT).
