Your basket is empty
BT Whole Home Wi-Fi
Customer rating: 2.0* (Write a review)
Quicklinx: CDXHWS00 Mfr#: 088269
Type: Whole Home Wi-Fi
Connectivity: Wireless
Speed: 1700Mbps
Antennas: 4
More than 50 in stock
£166.66 ex VAT
£199.99 inc VAT
Express delivery Delivered on Wednesday
Get Wi-Fi in every room or your money back!*
*30 day money back guarantee from date of purchase. The Whole Home Wi-fi app helps you position the discs to ensure you get complete coverage. If you still experience dead spots and are not satisfied you can return the product for a full refund. The product must be undamaged and in the original packaging. Your wi-fi speed will depend on your broadband input speed.
Internet from the loft to the cellar. And in every room between.
Staying glued to that box set season finale from living room to bath. Video calling your family on the other side of the world. Changing a fuse, with a YouTube tutorial guiding the way beside you. Sifting through boxes of memories in the loft, to the soundtrack of your teens.
Wherever you are in your home, Whole Home Wi-Fi puts what matters most at your fingertips. It brings super-fast, super-reliable Internet to every room. It talks to all your gadgets to make sure they're always connected to the fastest and strongest signal. And it's bristling with brilliant controls that put you in charge of a supercharged home network.
No more deadspots
With Whole Home Wi-Fi you can have your favourite TV, films, music and games in any room you wish. Three brilliant discs create a complete Wi-Fi network - which means no more notspots. Even when there's a laptop connected in the kitchen, smartphones upstairs and a tablet in the lounge - they all stay connected, all the time.
The technical bit
Whole Home Wi-Fi is an "intelligent self-configuring wireless network". That means it knows where you and your devices are, and when to switch them from one disc to another to give you the strongest and fastest connection it can. The three discs might be small, but their four built-in 2500 11ac 2.4GHZ and 5GHZ antennas pack a mighty wireless punch.
Keeping you safe
Whole Home Wi-Fi uses the latest security standards to keep your home network safe from outside interference. And one touch updates mean your home is always protected by the latest up-to-the-minute security patches and upgrades.
With brand new technology, one touch software updates and an app to control it all from, this is Wi-Fi at its simplest. It's Internet that just works.
You're in charge
First, the Whole Home Wi-Fi app tells you just where to put each disc for the best connection. Then once everything's working, it puts you in charge.
Want to see who's hogging your connection?
A helpful dashboard to see how your network is being used and who is connected.
Want to get everyone down for dinner? Or just get some time offline?
Pause the internet completely with one tap.
Disc lights too bright for your bedroom?
Turn them down, or off completely.
Technical gremlins?
The app will spot - and explain how to fix - them.
Legals - 30 day money back guarantee from date of purchase. The Whole Home Wi-fi app helps you position the discs to ensure you get complete coverage. If you still experience dead spots and are not satisfied you can return the product for a full refund. The product must be undamaged and in the original packaging. Your wi-fi speed will depend on your broadband input speed.
Resources
The following resources are available for the BT Whole Home Wi-Fi
Customer reviews
Write a review for the BT Whole Home Wi-Fi here!
Simply not good enough
Reviewed by Andrew Pemberton. Review Posted 01/03/2017
Much anticipation. But the system simply isn’t powerful enough to work in our old home with thick walls. Having said that, even siting some of the routers 5m away from each other, with line of sight, sometimes produces a ‘low quality’ warning, so it’s not just an issue with thick walls. My 5-year old Apple router and wifi extenders worked just as well. When you get the system to work, speeds are good. But we have to place the 3 routers so close to each other that we don’t get ‘whole home’; indeed, it seems routers in neighbouring rooms can’t ‘see’ each other at times, let alone getting a router to work upstairs with a good or excellent signal.
  • Overall 2*
  • Ease of use 4*
  • Value for money 3*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Speed: 1700Mbps
Antennas: 4
Brand: BT
Price Range Ex VAT: 150 - 300
