What does BT’s Home Hub 4r give you?
BT’s Home Hub 4r is a Dual-Band modem router with smart wireless technology which gives you a fast reliable wireless signal with your broadband, combined with a superb sleek and modern design.
Faster Wi-Fi through new Dual-Band technology
With Dual-Band technology you can improve the performance of your Wi-Fi around your home; with two antennas for each spectrum (2.4Ghz and 5Ghz) you can feel assured of a faster connection, especially on 5Ghz enabled devices. This is ideal for streaming content and high speed gaming!
A more reliable connection with smart Wi-Fi technology
The BT Home Hub 4r is designed with smart wireless technology that recognises there is interference on the chosen Wireless channel, this could be caused by a fridge, Microwave or your neighbours’ network! The BT Home Hub 4r will constantly monitor and switch the channel when interference is detected.
Make the most of your Broadband
BT's Wi-Fi Home Hotspot 500 Kit from BT offers a solution to a number of your broadband problems. Be it connecting a Smart TV in a different room to your router, generating Wi-Fi where your router doesn't reach or high speed streaming throughout your home, BT's Wi-Fi Home Hotspot 500 Kit can be used to help make the most of your broadband at home.
Works with other ISP’s
Previously only BT customers who subscribed to BT broadband were able to get their hands on BT’s iconic Home Hubs. This is no longer the case and now anyone can get their hands on the new BT Home Hub 4r. You can use a BT Home Hub 4r as your router even if you are a customer on cable.
Easy to set up and use
As you would expect from any product from BT it is easy to set up with minimal effort and fuss meaning you can start benefiting from the BT Home Hub 4r as quickly as you’d hoped. There is no problem connecting to Wi-Fi and there is a handy card with your credentials to connect your devices and a WPS button to connect enabled devices even quicker.
Automatic power management
The BT Home Hub 4r has the latest intelligent power management; hub functions are monitored and individually put into power save mode when not in use – meaning it continues to be great for your wallet long after purchase!
Power Consumption
- In Operation: 9.2W
- Idle: 6.3W
- Standby Mode: 0.2W
What’s in the box:
- BT Home Hub 4r
- Mains Power Adaptor
- Ethernet Cable
- WAN Cable
- 2 Filters
- DSL Cable
- User Guide
System requirements:
- Fibre Broadband and a modem with an Ethernet connection or an ADSL (normal copper) Broadband Line
- Required connection ports are an Ethernet port, or Wireless 802.11b, g, n or a
Other technical information
Ports and Sockets
- 1 x RJ45 Gigabit WAN interface for BT Infinity
- 3x RJ45 Ethernet LAN ports
- 1 x Gigabit Ethernet
- 1x USB 2.0 master socket
Buttons
- Wireless: WPS Reset (Pinhole)
- Restart
- On/Off power button
LED
-Power
-Broadband
-Wireless
Weight & dimensions
-301 (gms)
- 116 high x 236 wide x 31 deep (mm)
Wireless
- Dual band concurrent wireless
- 2.4GHz: 802.11n dual-stream 2x2 MIMO. Back compatible with 802.11 b/g
- 5GHz: 802.11n dual-stream 2x2 MIMO. Back compatible with 802.11a
-WPS wireless connection
-Smart Wireless – automated channel selection in 2.4 & 5GHz
-Wireless channel operation
-2.4GHz: 20MHz (default), 40MHz supported
-5GHz: 40MHz (default), 20MHz supported
-Up to 64 simultaneous wireless users supported
Wireless encryption
- 2.4GHz: WPA & WPA2 (default), WPA, WPA2 and WEP 64/40
- 5GHz: WPA2
Wireless Transmission speed
- 2.4GHz wireless: up to 300Mbps
- 5 GHz wireless: up to 300Mbps
- Up to 150 Mbps (20MHz)
- Up to 300 Mbps (40MHz)
Please note: The BT Home Hub 4r does not support BT TV, for BT TV customers the BT Home Hub 4 or the BT Home Hub 5 is recommended. Not suitable for Business Broadband - BT Business Hub 3 is recommended.
