BT Decor 2600 Premium Nuisance Call Blocker
Quicklinx: BTHZWS00 Mfr#: 083154
Type: Corded phone
Handsets Included: 1
Answer Machine: Yes
Nuisance Call Blocker: Yes
Mounting: Table-top
12 In Stock
£29.16 ex VAT
£34.99 inc VAT
Express delivery Delivered on Wednesday
with 100% call blocking and answer machine
Block 100% of nuisance calls so you only talk to the people you want to.
Featuring
  • Works with all landline providers
  • Large, clear display
  • Easy to use big buttons
  • Hearing aid compatible
  • Block 100% of nuisance calls1
  • Block up to 1000 numbers1
  • Virtual assistant filters and announces all unknown calls
  • Dedicated call blocking button
  • Outgoing call control to premium and mobile numbers
  • Record up to 30 minutes of messages
  • Save up to 200 contacts
  • Handsfree speaker
1 You need to have a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Fed up with nuisance calls?
There’s two call blocking modes: Announce and Answer Phone. In Announce mode any caller not on your contact list or already blocked will have to announce their name before getting through so you can choose whether to accept or reject the call. In Answer Phone mode all calls not in your contacts or allowed list are sent straight to your answer machine. You can also block numbers by area code so any call beginning with the code you enter will be blocked.
Packed with great features
You can save up to 200 contacts and have the option to block or unblock a contact at any time. Outgoing call control lets you set a PIN to protect calls to mobile and premium rate numbers to prevent any surprises on your bill, useful if you have children or for elderly relatives who may unknowingly dial numbers they don’t need to.
Need an answering machine?
Save up to 30 minutes of messages and see how many messages you’ve received clearly on the screen. And don’t miss important calls when away from home with remote access to your messages.
Want to talk handsfree?
Handsfree lets you talk to your caller without holding the handset, so you’re free to get on with other things, make notes or let other people in the room listen to the conversation over the loudspeaker.
1 Year Warranty
Resources
The following resources are available for the BT Decor 2600 Premium Nuisance Call Blocker
Type: Corded phone
Answer Machine: Yes
Mounting: Table-top
Big Button: No
Brand: BT
