This BT H31 corded monaural headset for desk phones is a headset which is offered in a stylish black and aluminum finish and is designed to deliver great sound quality. This BT H31 headset comes complete with a built in smart cord that makes your headset compatible with all standard and IP telephones so no need to purchase this cord separately. Connection to your phone is simple via the RJ11 cable plug at the end of the smart cord which connects the headset directly into your corded phones Headset Socket.
Adjustable for a comfortable fit
This BT H31 headband length can be adjusted for a comfortable fit on your head, comes with an earpad stabilizer and comfortable leatherette ear cushion and can be worn with the microphone either left or right facing. The microphone position can also be adjusted by rotating the boom and the voice tube holder can be extended or shortened to give maximum comfort and speech clarity. -
Quick Disconnect Cord (QD)
The quick disconnect cable conveniently allows you to disconnect the headset from the smart cord so you don't have to take off your headset or disconnect your headset from the phone socket when you want to leave your desk phone for short periods, the headset simply clips back to the smart cord when you are back at your desk phone.
- BT H31 - headset
- Product Type
- Headset - wired
- Recommended Use
- Phone
- Headphones Form Factor
- On-ear
- Connectivity Technology
- Wired
- Sound Output Mode
- Mono
- Audio Specifications
- Frequency Response 200 - 5000 Hz - Sensitivity 98 dB
- Impedance
- 16 Ohm
- Microphone
- Boom
- Microphone Operation Mode
- Mono
- Product Type
- Headset - wired
- 19 cm
- 5.5 cm
- 17 cm
- 100 g
- Body Material
- Aluminium, ABS plastic, Polyoxymethylene (POM)
- Recommended Use
- Phone
Audio Output
- On-ear
- Wired
- Sound Output Mode
- Mono
- 200 - 5000 Hz
- Sensitivity
- 98 dB
- Impedance
- 16 Ohm
- Diaphragm
- 40 mm
Microphone
- Boom
- Mono
- Sensitivity
- -61 dB
- Impedance
- 2200 Ohm
- Connector Type
- Headset (RJ-11)
- Cable Details
- Headset cable - 1.5 m
