Print, scan, copy and fax more efficiently with the MFC-L5750DW. With fast operating speeds and a large, user-friendly 12.3cm touchscreen display, this all-in-one mono laser device boasts optimum productivity and versatility to meet the needs of the most demanding business environment.
Maximise Performance & Reduce Print Spend
Versatile paper handling enables you to add multiple lower trays across the range. This provides maximum device uptime, as less time is spent replenishing paper trays. With the optional high yield toner cartridges, productivity is enhanced whilst reducing your overall printing costs.
Better reliability
Built to perform for longer and meet the demands of high output work environments, the L5000 range has been totally remodelled with robust build quality that’s even more resilient and hardwearing.
Tighter security
In today's business environment, we understand that organisations demand the highest levels of security. In order to address this, the L5000 range is enabled with secure function lock 3.0, 802.1x network security and Internet Protocol Security (IPsec). The range also boasts Print Archive, Secure Reset and Certificate Management.
Flexible print solutions from Brother
Our L5000 range is designed to seamlessly integrate and meet your business requirements. Compatible with a range of print software and services, Brother Solutions can be specifically tailored to your requirements and enables you to maximise your print efficiency and minimise costs.
Eco-friendly
The L5000 range is compliant with a number of environmental standards including German Blue Angel, Nordic Swan and Energy Star. As a result, not only does it help your business work more efficiently, it is also more energy efficient, reducing impact on the environment and lowering your costs at the same time.
- Brother MFC-L5750DW - multifunction printer - B/W - with Brother PRINT AirBag for 200000 pages
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Bundled Services
- Brother PRINT AirBag for 200000 pages
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 50000 pages
- Recommended Monthly Volume
- 3500 pages
- Max Copying Resolution
- Up to 1200 x 600 dpi
- Max Printing Speed
- Up to 40 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 4.85"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
- Standard Media Capacity
- 300 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, scan to FTP, scan to SMB
- Power
- AC 230 V (50/60Hz)
- 43.5 cm x 48.6 cm x 42.7 cm
- 16.5 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 3-year warranty
- Fax Type
- Plain paper
- Bundled Services
- Laser - monochrome
- 50000 pages
- 3500 pages
- Display Diagonal Size
- 4.85"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 256 MB
Copying
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 40 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3, IBM Proprinter, PDF 1.7, XPS, EPSON FX
- First Print Out Time B/W
- 7.2 sec
Scanning
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- Reception Memory Capacity
- Up to 500 pages
- Transmission Memory Capacity
- Up to 500 pages
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 300 station(s)
- Broadcast Transmission
- 350 stations
- Fax forwarding, automatic redialing, group dialling, Dual Access
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm)
- 300 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 120 g/m² , ADF - 50 sheets size: 105 x 147.3 mm - 215.9 x 355.6 mm weight: 64 g/m² - 90 g/m² , Bypass tray - 50 sheets size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 200 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 40 ppm - B/W , Printing: up to 20 spm - B/W duplex , Scanning: up to 24 ipm - B/W , Scanning: up to 20 ipm - colour , Scanning: up to 48 ipm - B/W duplex , Scanning: up to 34 ipm - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- SSL, WPA-PSK, TLS, IPsec, WPA2-PSK, TKIP, AES, ARP, Wi-Fi Direct
- Operating System Support
- Linux, MS Windows XP SP3, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, Apple Mac OS X 10.9, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11
- Voltage Required
- 645 Watt
- Power Consumption Standby
- 34 Watt
- Power Consumption Sleep
- 8 Watt
- First Copy Out Time B/W
- 9.2 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 2000 pages , 1 x drum (black) - up to 50000 pages - Brother DR3400
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 3 years
- 43.5 cm
- 48.6 cm
- 42.7 cm
- 16.5 kg
- Sound Emission
- 35 dBA (idle) / 54 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
Brother TN-3430 Black Standard Yield Toner | In Stock | £55.51 |
Brother TN-3480 Tonert 8000 Pages | In Stock | £95.37 |
Brother HLL6400/MFCL6900DW/T Drum Unit 30K | In Stock | £111.83 |
