Our best-selling, feature-packed MFC-J4510DW delivers impressive results quicker, so you can focus on getting the job done right.
Print straight from your mobile device and then send your finished work direct to any cloud-based service thanks to convenient wireless connectivity.
The swipeable 9.3cm touchscreen display provides easy access to the compact MFC-J4510DW's range of useful features, while the double-sided printing function and optional high-yield ink cartridges lend a hand when it comes to keeping your print costs to a minimum.
And, if A4 won't cut it this time round, you can also easily print the occasional A3 using the manual paper feed.
Landscape Print technology: the direction in printing
To create the Business Smart series, Brother redesigned the hardware, software and ink cartridges. This design allowed youto introduce the innovative Landscape Print technology, which stores and feeds paper in a landscape orientation. -
Fully integrated, sleek design
Sleek, modern color inkjet all-in-one that not only fits on your desk, but looks great too. The Brother Business Smart MFC-J4510dw features an eye-pleasing design and absolutely no protruding parts when not in use. -
Fastest speed in its class
With printing speeds up to 20 ppm/18 ppm you won't waste your valuable time waiting for printouts. -
Smallest footprint in its class
Conserve workspace with a compact design that's up to 35% smaller footprint than bulky competing models. Plus there is no protruding part when not in use. -
Low cost printing
Super high yield replacement inks cartridges help reduce your cost per page. Print up to 1,200 pages per cartridge. -
Intuitive TouchScreen display
Easy-to-use swipe - tap - drag 3.7" TouchScreen display. Intelligent TouchPanel only displays the keys you need. -
Prints up to 11" x 17" pages
Innovative Landscape Print technology lets you print on up to 11" x 17" paper (via bypass tray) from a machine roughly the same size as the page! -
Print wirelessly
Print over a Wi-Fi connection from a PC or mobile device. Compatible with AirPrint, Brother iPrint and scan, Cortado workplace, and Wi-Fi direct. -
Automatic document feeder
Lets you feed up to 20 pages at a time. More convenient than single sheet scanning, copying and faxing. -
Duplex printing
Print on both sides of a sheet of paper to help save paper, money and time. Less waste and less time replacing paper.
- Brother MFC-J4510DW - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- 4-ink
- Max Copying Speed
- Up to 12 ppm (mono) / up to 9 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Printing Speed
- Up to 20 ppm (mono) / up to 18 ppm (colour)
- Max Printing Resolution
- Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 2400 x 2400 dpi
- Display
- 3.7"
- Original Size
- 148 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 20 sheets
- Media Size
- 89 x 127 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, photo paper, coated paper
- Standard Media Capacity
- 150 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 50 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, AOSS
- Power
- AC 230 V (50/60Hz)
- 48 cm x 29 cm x 18.6 cm
- 9.3 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- Display Diagonal Size
- 3.7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 128 MB 128 MB
- Supported Flash Memory
- SD Memory Card, MultiMediaCard, Memory Stick Duo, USB flash drive, MultiMediaCardplus, Memory Stick PRO Duo, SDHC Memory Card, SDXC Memory Card
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Nozzle Configuration
- 420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 1.5 pl
- Ink Type
- Brother Innobella ink
Scanning
- Optical Resolution
- 2400 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Reception Memory Capacity
- Up to 200 pages
- Transmission Memory Capacity
- Up to 200 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 250 stations
- Fax forwarding, colour faxing, group dialling, Distinctive Ring Detection (DRD)
Document & Media Handling
- Min Original Size
- 148 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 20 sheets
- Min Media Size
- 89 x 127 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 127 x 203 mm, 102 x 152 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 127 x 178 mm, 89 x 127 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 1 sheet
- 50 sheets
- Input tray - 150 sheets size: 89 x 127 mm - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 220 g/m² , ADF - 20 sheets size: 148 x 148 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , Output tray - 50 sheets , Bypass tray - 1 sheet size: 89 x 127 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m²
- Speed Details
- Printing: up to 35 ppm (A4) - B/W draft , Printing: up to 27 ppm (A4) - colour draft , Copying: up to 12 ipm - B/W (ISO/IEC 24735) , Copying: up to 9 ipm - colour (ISO/IEC 24735) , Printing: up to 20 ipm (A4) - B/W (ISO/IEC 24734) , Printing: up to 18 ipm (A4) - colour (ISO/IEC 24734)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- LDAP, WEP, WPA-PSK, WPA2-PSK, WPS, IP filtering, ARP, Wi-Fi Direct
- Operating System Support
- Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows 7, Apple Mac OS X 10.6.x, MS Windows 7 64-bit Edition, Apple Mac OS X 10.5.8, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, Apple Mac OS X 10.7.x, MS Windows Server 2008 R2 x64 Edition, Windows 8
- Software Included
- Drivers & Utilities
- Voltage Required
- 21 Watt
- Power Consumption Standby
- 5.5 Watt
- Power Consumption Sleep
- 1.5 Watt
- Direct Printing Specifications
- PictBridge
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 48 cm
- 29 cm
- 18.6 cm
- 9.3 kg
- Shipping Width
- 56.5 cm
- Shipping Depth
- 26.6 cm
- Shipping Height
- 41.6 cm
- Shipping Weight
- 11.6 kg
- Sound Emission
- 50 dBA (operating)
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
