The powerful HL-5450DNT has been developed to offer the best of both worlds – high volume printing with completely dependable quality.
The standard total capacity of 800 pages allows you to work through big print runs efficiently. Your documents will be ready quickly too with up to 38ppm print speed and the first page out in under 8.5 seconds. And with the HL-5450DNT's straightforward Ethernet connectivity, it's all easily integrated with your existing systems.
Automatic duplex printing, booklet printing, up to 8,000 page toner cartridges, and 1,200dpi resolution all adds up to an impressive package that's as clever as it is compact.
- Brother HL-5450DNT - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 13.6 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 215.9 mm x 355.6 mm
- Print Speed
- Up to 38 ppm - B/W - A4 (210 x 297 mm) , Up to 40 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 18 spm - B/W duplex - A4 (210 x 297 mm) , Up to 18 spm - B/W duplex - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 1200 dpi
- Image Enhancement Technology
- Brother HQ1200
- Automatic Duplexing
- Interface
- USB, LAN
- AirPrint Enabled
- Processor
- 400 MHz
- RAM Installed (Max)
- 64 MB (320 MB) - DDR2 SDRAM - SO-DIMM 144-pin
- Language Simulation
- PostScript 3, PCL 6, BR-Script3, IBM ProPrinter XL, EPSON FX-850
- Media Type
- Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, thick paper, thin paper
- Total Media Capacity
- 800 sheets
- Media Handling
- 250-sheet input tray, 500-sheet input tray, 50-sheet multipurpose tray
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- Linux, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Apple MacOS X 10.5.8, Apple MacOS X 10.6.x, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x
- 1-year warranty
- 37.1 cm x 38.4 cm x 37.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- AirPrint Enabled
- 1200 dpi
- Brother HQ1200
- PostScript Support
- Standard
- First Print Out Time B/W
- 8.5 sec
- Fonts Included
- 66 x scalable PCL , 66 x scalable PostScript , 12 x bitmapped PCL
- Media Handling
- Processor
- 400 MHz
RAM
- 64 MB / 320 MB (max)
- Technology / Form Factor
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 800 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m²
- Max Media Capacity
- 800 sheets
- Output Trays Capacity
- 150 sheets
- Networking
- Print server
- Data Link Protocol
- TCP/IP, ICMP/IP, LPR/LPD, ARP, SMTP, FTP, APOP, BOOTP, DHCP, DNS, RARP
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP
- Kerberos, SSL, TLS, 802.1x
- Expansion Slots
- Memory - SO-DIMM 144-pin
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages ISO/IEC 19752
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 665 Watt
- Power Consumption Stand by / Sleep
- 4.7 Watt
- Software Included
- BRAdmin Light
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - 1 year
- 10 °C
- 32.5 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 34 dBA
- Sound Emission (Operating)
- 59 dBA
- Sound Emission (Quiet Mode)
- 54 dBA
- 37.1 cm
- 38.4 cm
- 37.5 cm
- 13.6 kg
- Width (Shipping)
- 66.4 cm
- Depth (Shipping)
- 50.3 cm
- Height (Shipping)
- 67 cm
- Weight (Shipping)
- 19.7 kg
Brother DR-3300 Drum Unit | In Stock | £123.26 |
Brother TN3330 Toner Cartridge - Black | In Stock | £57.13 |
Brother TN3380 Black Toner Cartridge | In Stock | £90.03 |
