Brother HL-5440D High Speed Mono Laser Printer
Quicklinx: 87GGWS00 Mfr#: HL5440DU1
The HL-5440D has been specially designed to handle high pressure workloads in a busy office as a matter of routine.
Offering professional 1,200dpi resolution, its output runs up to 38ppm, with the first page out in under 8.5 seconds. The standard paper capacity is an impressive 300 sheets, and you can easily add more if required.
And with the option of an 8,000-page high-yield toner cartridge, plus automatic duplex printing with booklet capability, the HL-5440D does more, faster – and for less.
  • Secure
    Be in control with secure local connectivity. The HL-5440D offers both Windows and Mac compatibility. Its secure USB interface provides full speed connectivity for most modern business devices.
  • Cost effective
    A range of cost saving features including toner save mode and booklet printing allow significant reductions on print costs. The optional 8,0001 page high yield toner cartridge together with the separate drum unit means you can be sure of exceedingly low running costs.
  • Professional
    Thanks to the 1,200 x 1,200dpi print resolution you'll get sharp crisp text and accurate reproduction of even the finest details on the page. With automatic 2-sided and booklet printing as standard, you can produce professional reports and presentations and reduce paper consumption by up to 75%.
  • Compact
    With office space at a premium the HL-5440D is designed to fit in, with its compact size and stylish design making it work in even the smallest of spaces.
  • Productive
    A first page out time of less than 8.5 seconds and an impressive print speed of up to 38ppm ensures large volume print jobs are handled with ease and deadlines are met.
Brother HL-5440D - printer - B/W - laser
Printer Type
Personal printer - laser - B/W
10.4 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 38 ppm - B/W , Up to 18 ppm - B/W duplex
Max Resolution (B&W)
2400 x 600 dpi
Image Enhancement Technology
Brother HQ1200
Automatic Duplexing
Parallel, USB
400 MHz
RAM Installed (Max)
64 MB
Language Simulation
PCL 6, BR-Script3, IBM ProPrinter XL, EPSON FX-850
Barcodes
Code 39, UCC/EAN-128, ISBN, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Interleaved 2 of 5, Postnet, FIM, Code 128B, Code 128C, Code 128A
Media Type
Envelopes, labels, plain paper, bond paper, recycled paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Monthly Duty Cycle (max)
50000 pages
Recommended Monthly Volume
500 - 3000 pages
Linux, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition, Apple MacOS X 10.5.8, Apple MacOS X 10.6.x, Apple MacOS X 10.7.x
Microsoft Certification
Compatible with Windows 7
37.1 cm x 38.4 cm x 24.5 cm
Printer Type
Personal printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
Parallel, USB
2400 x 600 dpi
Brother HQ1200
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
8.5 sec
Language Simulation
Fonts Included
66 x scalable PCL , 66 x scalable PostScript , 12 x bitmapped PCL
Barcodes
Media Handling
400 MHz
RAM
RAM Installed (Max)
64 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm), 76.2 x 127 mm, 215.9 x 355.6 mm
Media Weight
60 g/m² - 163 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x automatic - 50 sheets - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m²
Max Media Capacity
800 sheets
Output Trays Capacity
150 sheets
Duty Cycle
50000 pages
500 - 3000 pages
Expansion Slots
1 x USB 2.0 , 1 x parallel - 36 PIN Centronics
Consumables Included
1 x toner cartridge (black) - up to 2000 pages ISO/IEC 19752 , 1 x drum - up to 25000 pages
Power supply - internal
700 Watt
Power Consumption Stand by / Sleep
4.8 Watt
Environmental Standards
Blue Angel
ENERGY STAR
Limited warranty - 2 years - carry-in , Limited warranty - 1 year - on-site
Sound Emission (Idle)
34 dBA
Sound Emission (Operating)
59 dBA
Sound Emission (Quiet Mode)
54 dBA
37.1 cm
38.4 cm
24.5 cm
10.4 kg
Width (Shipping)
49.9 cm
Depth (Shipping)
47.8 cm
Height (Shipping)
38 cm
Weight (Shipping)
12.4 kg
87GG Brother DR-3300 Drum Unit In Stock £123.26
87GG Brother TN3330 Toner Cartridge - Black In Stock £57.13
87GG Brother TN3380 Black Toner Cartridge In Stock £90.03
