The HL-2135W offers you all the ease and productivity benefits that come with being able to print wirelessly from anywhere in your office, in a machine with a remarkably small footprint.
You'll get print speeds up to 20ppm and there's a 250-sheet paper tray too, so you can do longer print runs without any interruptions.
Add in the option of economic 1,000 page cartridges combined with crisp 600dpi print resolution as standard, and it's easy to see why the HL-2135W makes a professional addition to any home office.
Outstanding print quality
For budget-conscious users, the HL-2100 series is a great choice for producing high-quality output. HL-1200 resolution (up to 2400 x 600 dpi) will ensure that your letters, reports, spreadsheets and other important documents have crisp text and sharp graphics. -
Flexible paper handling
The HL-2100 series can handle letter and legal size paper and a variety of media types. For fewer paper refills, the printer features an enclosed universal paper tray that can hold up to 250 sheets. A manual by-pass slot is available for printing envelopes, letterhead and card stock. -
Affordable to own and operate
The HL-2100 series printer is not only affordable to purchase, but also offers an economical cost-per-page, to keep your running costs even lower. -
Toner-save mode
For printing non-critical documents, the HL-2100 series printer offers a toner-save mode. This feature can save you money by reducing toner use and extending the life of your toner cartridge. -
Easy-to-use and maintain
The HL-2100 series printer is simple to set up and operate. The excellent driver installation quickly guides users through the process. USB users can install their driver in just five clicks!
- Brother HL-2135W - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 6.7 kg
- Media Size Class
- A4
- Max Media Size
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 69.9 mm x 116 mm
- Max Media Size (Custom)
- 215.9 mm x 406.4 mm
- Print Speed
- Up to 20 ppm - B/W
- Max Resolution (B&W)
- 2400 x 600 dpi
- Image Enhancement Technology
- Brother HQ1200
- Interface
- USB, Wi-Fi
- Processor
- 200 MHz
- RAM Installed (Max)
- 16 MB
- Language Simulation
- Windows GDI driver
- Media Type
- Envelopes, transparencies, labels, plain paper, bond paper, recycled paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet manual tray
- Networking
- Print server - IEEE 802.11b, IEEE 802.11g - integrated
- Printer Features
- AirStation OneTouch Secure System (AOSS)
- System Requirements
- Linux, Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5.x, Apple MacOS X 10.4.11, Apple MacOS X 10.6.x
- 1-year warranty
- 36.8 cm x 36 cm x 18.3 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- USB, Wi-Fi
- 2400 x 600 dpi
- Brother HQ1200
- PostScript Support
- Standard
- First Print Out Time B/W
- 10 sec
- Printer Features
- Media Handling
- Processor
- 200 MHz
RAM
- 16 MB
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- 69.9 mm x 116 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet - 215.9 x 406.4 mm weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 100 sheets
- Networking
- Print server - integrated
- Data Link Protocol
- TCP/IP, SMTP, POP3
- WEP, WPA-PSK, WPA2-PSK
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages ISO/IEC 19752 , 1 x drum - up to 12000 pages
- Power Device
- Power supply - internal
- 421 Watt
- Power Consumption Stand by / Sleep
- 62 Watt
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 1 year
- Sound Emission (Idle)
- 31 dBA
- Sound Emission (Operating)
- 53 dBA
- 36.8 cm
- 36 cm
- 18.3 cm
- 6.7 kg
- Width (Shipping)
- 47.5 cm
- Depth (Shipping)
- 45.4 cm
- Height (Shipping)
- 33.1 cm
- Weight (Shipping)
- 8 kg
Brother TN2010 Black Toner Cartridge 1k Yield | In Stock | £27.87 |
