Brother DCP-L2540DN Mono Laser Mulitfunction Printer
Quicklinx: 9NJGWS00 Mfr#: DCPL2540DNZU1
A great little mono laser printer, scanner and copier for the small or home office. Enjoy high-speed printing up to 30 ppm, while double-sided printing, 250 sheet paper tray and 35-sheet automatic document feeder make office life even easier.
Brother DCP-L2540DN - multifunction printer - B/W
Multifunction printer
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 26 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 30 ppm
Max Printing Resolution
Up to 600 x 2400 dpi
Scanning
600 x 2400 dpi
Original Size
215.9 x 355.6 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN
Office Machine Features
Scan to network
AC 230 V (50/60Hz)
40.9 cm x 39.85 cm x 31.65 cm
11.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
Printing Technology
Laser - monochrome
Display
2 lines x 16 characters
USB 2.0, LAN
Scan to network
Standard Memory
32 MB
Copying
Max Copying Speed
Up to 26 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
2 on 1, 4 on 1
Printing
Max Printing Speed
Up to 30 ppm
Printer Drivers / Emulations
PCL 6, PostScript 3, BR-Script 3, PDF 1.7, XPS
Image Enhancement Technology
Brother HQ1200
Automatic Duplexing
First Print Out Time B/W
8.5 sec
Scanning
Optical Resolution
600 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
30-bit
Document & Media Handling
Max Original Size
215.9 x 355.6 mm
Original Type
Sheets
35 sheets
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
250 sheets
1 sheet
100 sheets
ADF - 35 sheets size: 147.3 x 147.3 mm - 215.9 x 355.6 mm weight: 64 g/m² - 90 g/m² , Input tray - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 30 ppm (A4) - B/W , Printing: up to 15 spm (A4) - B/W duplex , Copying: up to 26 ppm (A4) - B/W
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
ARP
Operating System Support
MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Vista (64-bit versions), MS Windows Server 2008 R2, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8, Windows 8 64-bit, Windows 8.1, Windows 8.1 64-bit, Apple Mac OS X 10.7.5, MS Windows Server 2003 (32/64-bits), MS Windows Server 2008 (32/64-bits), Apple Mac OS X 10.9.x
AC 230 V (50/60Hz)
510 Watt
Power Consumption Standby
60 Watt
Power Consumption Sleep
6.6 Watt
First Copy Out Time B/W
10 sec
Consumables Included
1 x toner cartridge (black) - up to 1200 pages
Nordic Ecolabel, IEC 60825-1:2007
ENERGY STAR Certified
Blue Angel Compliant
40.9 cm
39.85 cm
31.65 cm
11.2 kg
Shipping Width
56.7 cm
Shipping Depth
51.7 cm
Shipping Height
43.5 cm
Shipping Weight
14.2 kg
Sound Emission
33 dBA (idle) / 50 dBA (operating)
10 °C
32 °C
20 - 80% (non-condensing)
