This mono laser printer, scanner and copier is an ideal entry-level machine for the small or home office. Easy to use, it's still quick and features double-sided printing as standard to help reduce waste.
- Brother DCP-L2500D - multifunction printer - B/W
- Multifunction printer
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 10000 pages
- Recommended Monthly Volume
- 250 - 2000 pages
- Max Copying Speed
- Up to 26 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 26 ppm
- Max Printing Resolution
- Up to 600 x 2400 dpi
- Scanning
- 600 x 2400 dpi
- Original Type
- Sheets
- Media Size
- A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0
- Office Machine Features
- Scan to e-mail
- Power
- AC 230 V (50/60Hz)
- 40.9 cm x 39.85 cm x 26.7 cm
- 9.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Laser - monochrome
- 10000 pages
- 250 - 2000 pages
- Display
- 2 lines x 16 characters
- Interface
- USB 2.0
- Scan to e-mail
- Standard Memory
- 32 MB
Copying
- Max Copying Speed
- Up to 26 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1
Printing
- Up to 26 ppm
- Printer Drivers / Emulations
- Windows GDI driver
- Image Enhancement Technology
- Brother HQ1200
- First Print Out Time B/W
- 8.5 sec
Scanning
- Optical Resolution
- 600 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 30-bit
Document & Media Handling
- Original Type
- Sheets
- Max Media Size
- A4
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm)
- 250 sheets
- 1 sheet
- 100 sheets
- Input tray - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet size: 76.2 x 127 mm - 215.9 x 355.6 mm weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 26 ppm (A4) - B/W , Printing: up to 13 spm (A4) - B/W duplex , Copying: up to 26 ppm (A4) - B/W
- 1 x USB 2.0 - 4 pin USB Type B
- ARP
- Operating System Support
- Linux, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Vista (64-bit versions), Apple Mac OS X 10.8.x, Windows 8, Windows 8 64-bit, Apple Mac OS X 10.7.5, Apple Mac OS X 10.9.x
- Voltage Required
- 480 Watt
- Power Consumption Standby
- 60 Watt
- Power Consumption Sleep
- 6.6 Watt
- First Copy Out Time B/W
- 10 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages
- Nordic Ecolabel, IEC 60825-1:2007
- ENERGY STAR Certified
- Blue Angel Compliant
- 40.9 cm
- 39.85 cm
- 26.7 cm
- 9.7 kg
- Shipping Width
- 56.7 cm
- Shipping Depth
- 51.7 cm
- Shipping Height
- 41.4 cm
- Shipping Weight
- 12.5 kg
- Sound Emission
- 33 dBA (idle) / 49 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
