Compact Mono Laser All-in-One Printer
This versatile all-in-one offers high quality prints, scans and copies in one compact multifunction unit. You'll appreciate being able to print fast at up to 20 pages per minute (ppm), and your first page will come out after only 10 seconds. Sharp, crisp text and accurate reproduction of fine detail are a given too, with the DCP-7055's high print resolution for outstanding results. The high resolution flatbed scanner produces high quality color images of scanned documents straight to your PC. The single sheet multi-purpose tray can be used to print on thicker media such as envelopes whilst the standard paper tray boasts an impressive 250 sheet capacity so you'll replenish it less frequently.
The DCP-7055 has been designed with the budget conscious buyer in mind. A range of software features including N-in-1 printing where multi-page documents can be reduced to just one page and toner save mode can reduce print costs considerably. All supplies, including the drum, can be replaced individually. This saves you money as you only pay for what you've used. When the DCP-7055 is in sleep mode, it consumes just 0.9 watts of power. It is the most energy efficient laser multifunction from Brother ever and has helped it to achieve ENERGY STAR certification thanks to its outstanding energy efficiency.
Benefits
Low cost and compact makes this ideal for a small office
Save time with fast 20ppm print and copy speed
First page out time of less than 10 seconds
High resolution colour scanning plus scan to PDF feature
Separate drum and toner to help keep costs down - only replace the one that's run out
Less refilling with a 250 sheet paper capacity
Hi-Speed USB 2.0 connection
Added peace of mind with free 12-month warranty and lifetime technical support
Green and clean technology that meets Energy Star environmental standard
Versatile
With high speed printing and copying at up to 20 pages per minute, the DCP-7055 produces high quality documents fast. The 250 sheet built-in paper tray means you will be replenishing paper less frequently making you more efficient in your daily tasks. The single sheet multi-purpose tray allows you to print on thicker media such as envelopes. The high resolution color scanner means you can create digital copies of hard copy documents quickly and easily. -
Easy to use
Although the DCP-7055 is equipped with a wealth of impressive functions, the intuitive control panel together with the 2 line LCD screen means you will be familiar with the most frequently used features in no time. An easy to follow menu structure means the machine is quick and easy to set-up and configure. Replacing the toner cartridge is simple thanks to the front operation. -
Value for money
With the DCP-7055, high performance doesn't mean high costs. Save paper and use less toner by reducing 2, 4, 9, 16 or 25 pages onto just one A4 sheet with N-in-1 printing. Using Toner Save Mode can further reduce your running costs. -
Environmentally friendly
The DCP-7055's ENERGY STAR certified energy efficiency means low power consumption for you. Brother's separate toner and drum system significantly reduces waste.
- Brother DCP-7055 - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 8000 impressions
- Recommended Monthly Volume
- 250 - 1600 pages
- Max Copying Speed
- Up to 20 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 20 ppm
- Max Printing Resolution
- Up to 2400 x 600 dpi
- Scanning
- 600 x 2400 dpi
- Original Size
- A4 (210 x 297 mm) (max)
- Original Type
- Sheets
- Media Size
- 76.2 x 116 mm (min) - 216 x 406.4 mm (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0
- Office Machine Features
- Scan to e-mail
- 40.5 cm x 39.9 cm x 26.8 cm
- 9.8 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Copier Type
- Digital
- Laser - monochrome
- 8000 impressions
- 250 - 1600 pages
- Display
- 2 lines x 16 characters
- Interface
- USB 2.0
- Scan to e-mail
- Standard Memory
- 16 MB 16 MB
Copying
- Max Copying Speed
- Up to 20 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1
Printing
- Up to 20 ppm
- Image Enhancement Technology
- Brother HQ1200
Scanning
- Optical Resolution
- 600 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Max Original Size
- A4 (210 x 297 mm)
- Original Type
- Sheets
- Min Media Size
- 76.2 x 116 mm
- Max Media Size
- Other
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm)
- 250 sheets
- 1 sheet
- 100 sheets
- Input tray - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 1 sheet - 216 x 406.4 mm weight: 60 g/m² - 163 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 20 ppm - B/W , Copying: up to 20 ppm - B/W
- 1 x USB 2.0
- Operating System Support
- Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.4.11, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows 2000 Professional, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), Apple Mac OS X 10.5.x, MS Windows Server 2008, MS Windows Server 2008 R2
- 445 Watt
- Power Consumption Standby
- 55 Watt
- Power Consumption Sleep
- 0.9 Watt
- Warm-Up Time
- 7 sec
- First Copy Out Time B/W
- 12 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages - Brother TN2010 , 1 x drum - up to 12000 pages - Brother DR2200
- ENERGY STAR Certified
- Limited warranty - 1 year
- 40.5 cm
- 39.9 cm
- 26.8 cm
- 9.8 kg
- Shipping Width
- 52.7 cm
- Shipping Depth
- 51 cm
- Shipping Height
- 44 cm
- Shipping Weight
- 12.9 kg
- Sound Emission
- 30 dBA (idle) / 53 dBA (operating)
Brother BRO DR2200 DRUM HL2240/2240D/ | In Stock | £53.38 |
Brother TN2010 Black Toner Cartridge 1k Yield | In Stock | £27.87 |
