The high-speed automatic color document scanners (ADS-2600W) can handle a variety of documents from paper to plastic cards, and offer fast speeds of up to 48 ipm (images per minute), high-quality scanning at up to 1,200 dpi and 'one touch' technology for ease of use. It can also scan documents to various files types, offer document management solutions with software from companies such as Nuance and Bizcard, have 2-sided scanning capability and a 50-page automatic document feeder (ADF). The ADS-2600W comes with network and Wi-Fi capability as standard, as well as a userfriendly 9.3 cm color touch screen.
- Brother ADS-2600W - document scanner - desktop - LAN, Wi-Fi(n)
- Document scanner - desktop
- Interface Type
- LAN, Wi-Fi(n)
- Max Supported Document Size
- 216 x 863 mm
- Input Type
- Grayscale / Color Depth
- 8-bit (256 colours) / 30-bit colour
- Grayscale / Color Depth (External)
- 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Interpolated Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 24 ppm (mono) / 24 ppm (colour)
- Max Document Size
- 216 mm x 863 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
- Microsoft Certification
- Compatible with Windows 7
- 29.9 cm x 22 cm x 17.9 cm
- 3.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- LAN, Wi-Fi(n)
- 216 x 863 mm
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 30-bit colour
- Colour Depth (External)
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- Max Document Scan Speed B/W
- 24 ppm
- Max Document Scan Speed Colour
- 24 ppm
- Scanner Speed Details
- 24 ppm - black & white , 24 ppm - colour , 48 ipm - duplex - black & white , 48 ipm - duplex - colour
- Scanner Features
- Scan to portable USB drive, Ultrasonic multifeed sensor, AirStation One-Touch Secure System (AOSS), Wi-Fi Protected Setup, 3.7" touch screen LCD display
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 863 mm
- Plain paper
- Supported Document Size Details
- ADF
- Automatic
- 50 sheets
- Supported Protocols
- NetBEUI/NetBIOS, DHCP, BOOTP, DNS, FTP, HTTP, SMTP, ARP, ICMP, SNMP 1, SNMP 2c, SNMP 3, HTTPS, TLS, RARP, TFTP, LDAP, SSL, CIFS
- USB 2.0 - Type B , LAN , USB - Type A
- Included Accessories
- A3 carrier sheet
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Voltage Required
- Power Consumption Operational (Standby)
- 20 Watt (4 Watt)
- Software Included
- Presto! BizCard 6, Presto! BizCard 5 for Mac, Brother Control Center 4, Nuance PDF Converter Professional 7, Brother Control Center 2, Nuance PaperPort 12 SE, Presto! PageManager 9 for Mac
- OS Required
- 29.9 cm
- 22 cm
- 17.9 cm
- 3.6 kg
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 49 dB
