Brother 2400X600DPI A4 Colour Laser Multifunction Printer
Quicklinx: 9W6SWS00 Mfr#: DCP-9020CDWZU1
If your business wants great value and the brilliance of color, look no further than this all-in-one. Its part of Brother's exciting range of next generation color LED printers, designed for high performance and better value.
Offering you high quality, fast color printing at 18 pages per minute, it combines color copy and scan capabilities in one compact machine. It means that investing in color is now affordable, with low power consumption and high yield color cartridges for a low cost per page.
Built for reliability, it won't let you down. In fact it's been designed to improve productivity, packed full of time-saving features, from 2-sided printing as standard, a 250 sheet lower paper tray, easy to use color touch screen, the flexibility to print from USB, and web-based applications such as Apple AirPrint and Google Cloud Print, as well as wireless connectivity to share resources. There's also a range of scanning features such as push scanning and scan to network so information can be shared across your business quickly.
Brother DCP-9020CDW - multifunction printer - colour
Multifunction printer
Printing Technology
LED (colour)
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
300 - 1500 pages
Max Copying Speed
Up to 18 ppm (mono) / up to 18 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Scanning
1200 x 2400 dpi
Display
3.7"
Original Size
147.3 x 147.3 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 116 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper
Standard Media Capacity
250 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail, scan to network, AOSS
AC 230 V (50/60Hz)
41 cm x 48.3 cm x 41 cm
18.3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, Blue Angel
1-year warranty
Printing Technology
LED - colour
30000 pages
300 - 1500 pages
Display Diagonal Size
3.7"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
192 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, BR-Script 3
Automatic Duplexing
First Print Out Time B/W
16 sec
First Print Out Time Colour
16 sec
Scanning
Optical Resolution
1200 x 2400 dpi
Interpolated Resolution
19200 x 19200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Document & Media Handling
Min Original Size
147.3 x 147.3 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 116 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
250 sheets
1 sheet
100 sheets
ADF - 35 sheets size: 147.3 x 147.3 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Output tray - 100 sheets , Bypass tray - 1 sheet size: 76.2 x 116 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Speed Details
Printing: up to 18 ppm (A4) - B/W , Printing: up to 18 ppm (A4) - colour , Printing: up to 7 spm (A4) - B/W duplex , Printing: up to 7 spm (A4) - colour duplex , Copying: up to 18 ppm (A4) - B/W , Copying: up to 18 ppm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
Kerberos, SSL, WEP, WPA-PSK, TLS, 802.1x, WPA2-PSK, WPS, ARP, Wi-Fi Direct
Operating System Support
Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, Apple Mac OS X 10.6.8 or later, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8, Windows 8 64-bit
AC 230 V (50/60Hz)
380 Watt
Power Consumption Standby
70 Watt
Power Consumption Sleep
7 Watt
Warm-Up Time
24 sec
First Copy Out Time B/W
19 sec
First Copy Out Time Colour
22 sec
Consumables Included
1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages
ENERGY STAR Certified
Blue Angel Compliant
Limited warranty - 1 year
41 cm
48.3 cm
41 cm
18.3 kg
Shipping Width
60.2 cm
Shipping Depth
53.4 cm
Shipping Height
56.5 cm
Shipping Weight
27.7 kg
Sound Emission
33 dBA (idle) / 53 dBA (operating)
10 °C
32.5 °C
20 - 80% (non-condensing)
