If your business wants great value and the brilliance of color, look no further than this all-in-one. Its part of Brother's exciting range of next generation color LED printers, designed for high performance and better value.
Offering you high quality, fast color printing at 18 pages per minute, it combines color copy and scan capabilities in one compact machine. It means that investing in color is now affordable, with low power consumption and high yield color cartridges for a low cost per page.
Built for reliability, it won't let you down. In fact it's been designed to improve productivity, packed full of time-saving features, from 2-sided printing as standard, a 250 sheet lower paper tray, easy to use color touch screen, the flexibility to print from USB, and web-based applications such as Apple AirPrint and Google Cloud Print, as well as wireless connectivity to share resources. There's also a range of scanning features such as push scanning and scan to network so information can be shared across your business quickly.
- Brother DCP-9020CDW - multifunction printer - colour
- Multifunction printer
- Printing Technology
- LED (colour)
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 300 - 1500 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 18 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Display
- 3.7"
- Original Size
- 147.3 x 147.3 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 116 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper, thin paper, thick paper, glossy paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to network, AOSS
- Power
- AC 230 V (50/60Hz)
- 41 cm x 48.3 cm x 41 cm
- 18.3 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- LED - colour
- 30000 pages
- 300 - 1500 pages
- Display Diagonal Size
- 3.7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 192 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL 6, BR-Script 3
- First Print Out Time B/W
- 16 sec
- First Print Out Time Colour
- 16 sec
Scanning
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Document & Media Handling
- Min Original Size
- 147.3 x 147.3 mm
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 116 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
- 250 sheets
- 1 sheet
- 100 sheets
- ADF - 35 sheets size: 147.3 x 147.3 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Output tray - 100 sheets , Bypass tray - 1 sheet size: 76.2 x 116 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Speed Details
- Printing: up to 18 ppm (A4) - B/W , Printing: up to 18 ppm (A4) - colour , Printing: up to 7 spm (A4) - B/W duplex , Printing: up to 7 spm (A4) - colour duplex , Copying: up to 18 ppm (A4) - B/W , Copying: up to 18 ppm (A4) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Kerberos, SSL, WEP, WPA-PSK, TLS, 802.1x, WPA2-PSK, WPS, ARP, Wi-Fi Direct
- Operating System Support
- Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.7.x, Apple Mac OS X 10.6.8 or later, Apple Mac OS X 10.8.x, MS Windows Server 2012, Windows 8, Windows 8 64-bit
- Voltage Required
- 380 Watt
- Power Consumption Standby
- 70 Watt
- Power Consumption Sleep
- 7 Watt
- Warm-Up Time
- 24 sec
- First Copy Out Time B/W
- 19 sec
- First Copy Out Time Colour
- 22 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year
- 41 cm
- 48.3 cm
- 41 cm
- 18.3 kg
- Shipping Width
- 60.2 cm
- Shipping Depth
- 53.4 cm
- Shipping Height
- 56.5 cm
- Shipping Weight
- 27.7 kg
- Sound Emission
- 33 dBA (idle) / 53 dBA (operating)
- 10 °C
- 32.5 °C
- 20 - 80% (non-condensing)
