Rebirth of the cool
Finally, a USB mic that's not only easy to use, but sounds as good on your desktop as it does in a professional recording studio. Meet the Snowball; the world's first professional USB mic. Whether you're recording a guitar at your kitchen table or a complete band in the studio, the Snowball can capture it with detail unheard of before in a USB mic.
Works with the iPad!
Snowball and Snowflake can be used to record on iPad via Apple's camera connection kit (USB-to-30-pin) or the Lightning to USB camera adapter! Using these adapters, you can get Blue's studio-quality audio on your iPad with any recording app, including GarageBand.
The Snowball is a direct plug n' play mic that connects to either a Mac or PC - no additional software is needed. With its dual capsule design and unique three-pattern switch (cardioid, cardioid with -10dB pad and omni), the Snowball can handle everything from soft vocals to the loudest garage band - and it's ideal for podcasting.
Record studio-quality vocals, instruments, podcasts and more
Snowball USB microphones bring the same Blue heritage that powers the world's most elite studios and artists to your home setup, so you can achieve studio-quality sound on your desktop with ease. Snowball utilizes a unique dual capsule design to ensure rich, detailed sound for any project. -
It doesn't get any easier
Want to get studio-quality audio quickly and easily? Done. The Snowball family's excellent sound quality and easy operation make them the industry-standard USB microphones for podcasting and desktop recording. And rightly so - with Snowball, you can record and stream stunningly detailed audio as soon as you rip open the packaging and plug it into to your Mac or PC. It's as easy as... well... rolling a snowball, and you don't have to wear goofy mittens to use it. -
From video games to conference calls
Snowball USB microphones are perfect for streaming live audio in stunning quality. Take your Twitch channel to the professional level with pristine audio. Host VoIP and conference calls without missing a single detail. Every Snowball computer microphone delivers precisely what you need to get the most out of your projects. -
Capture a variety of sources
The Snowball USB microphone is perfect for recording and streaming on your desktop. It gives you the flexibility and versatility to capture music, podcasts, game streams, YouTube videos and more in stunning sound quality. You get three pickup settings - cardioid, omni, and cardioid with -10dB pad - to accommodate any recording situation. -
Choose the snowball that matches your style
Not only do Snowball USB microphones have a reputation for great sound quality, they've also got an eye for fashion. With cutting-edge capabilities and the looks to match, Snowball always comes through with flying colors.
- Blue Microphones Snowball - microphone
- Product Type
- Microphone
- Recommended Use
- Computer
- Microphone
- External
- Microphone Technology
- Electret condenser
- Microphone Operation Mode
- Cardioid, omni-directional
- Product Type
- Microphone
- 460 g
- Recommended Use
- Computer
Microphone
- Connectivity Technology
- Wired
- Frequency Response
- 40 - 18000 Hz
- Connector Type
- USB
- Included Accessories
- Tripod
