The BiPac P106N is a Homeplug AV 200 Mbps Wireless 'N' starter kit, comprising of one 2073 wired AV Homeplug adapter and one 2073N wireless 'N' AV Homeplug adapter. Simply connect the 2073 plug to your router via the supplied Ethernet cable and create a mini wireless 'N' hotspot anywhere in the home with the 2073N. Great for use in larger houses, garages, outbuildings, or where the thickness of the walls prevents good wireless coverage. The P106N will carry your internet connection through your existing powerlines to inaccessible parts of the premises, and then relay it wirelessly to your laptop, desktop, games console, printer, camera or any wireless device in client mode. WEP, WPA, WPA2 wireless encryption can be set up via a simple web interface to maximise your wireless security Compatible with Billion's existing Homeplug AV devices, 2071, 2072, 2074 and P104.
Features:
* Network PCs in the home or office through existing AC powerlines - 200 Mbps transmission rate
* Create a mini wireless hotspot anywhere in the home or garage/outbuilding
* 300 Mbps plus wireless security with WEP, WPA, WPA2
* Use wireless bridging to connect between different circuits/phases
* Reversible clips - unit can be rotated 180 degrees to avoid obstructions
* 60% power saving mode when idle
Energy efficiency
Due to climate change, Green IT is becoming a big issue in current times. With the Smart Power Saving technology, the BiPAC 2073 R2 can automatically detect its Ethernet connection. When an Ethernet-based device is powered down or disconnected, the BiPAC 2073 R2 adapter will automatically fall into sleep mode, which reduces power consumption significantly. Furthermore, when the current usage is in full operation, the adapter can reduce its power consumption which in turn saves money on your electricity bill. Create a "Green" home with the BiPAC 2073 R2 and become more energy efficient! -
No extra wiring needed to set up an in-home network
With The BiPAC 2073 R2, you can create a network with high-speed bandwidth to connect computers and game consoles without the need for further drilling or extra wires. Just one touch of the "Sync" button to install the bridge utility and your high-speed network is ready. It's as easy as simply plugging in your Billion networking devices and using the power cables in your home. -
Smooth traffic and prioritization
Quality of Service (QoS) control guarantees the transmission quality by automatically prioritizing data. The BiPAC 2073 R2 will automatically recognize the bandwidth needs of voice and video applications. QoS prioritizes the data in order to guarantee optimal transmission quality. TV and video images are received and displayed with absolute smoothness. QoS also guarantees clear and instant transmission of voice data, even when other applications are running on the network at the same time. QoS makes your network a pleasure to use. -
Immunity from noise and intervention
Unlike other HomePlug devices, the BiPAC 2073 R2 supports superior and noise-immune data transmission over in-home electrical power lines. Even when your family turns on an electronic device or turns off a light, you won't experience any interruption to latency-sensitive applications such as multimedia or video being shared with your family in another room.
- Billion BIPAC P106N - Starter Kit - powerline adapter - 802.11b/g/n - desktop
- Powerline adapter
- Enclosure Type
- Desktop
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 200 Mbps
- Auto-uplink (auto MDI/MDI-X), IGMP snooping, IPv6 support, Wireless Distribution System (WDS) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), IPv4 support
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.3x, IEEE 802.11g, IEEE 802.11n, HomePlug AV
- 11.2 cm x 7.7 cm x 5.3 cm
- System Requirements
- Microsoft Windows 98 Second Edition / Windows ME, Microsoft Windows 98/2000/XP/Vista/7
- Powerline adapter
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 200 Mbps
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, 128-bit AES, WPA2-PSK
- Built-in Devices
- Radio access point
- Status Indicators
- Port status, power, link/activity
Line Properties
- Line Coding Format
- 8 QAM, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, ROBO, 1024 QAM
- 1 x 10Base-T/100Base-TX - RJ-45 , 1 x HomePlug AV - power
Aerial
- Aerial
- External integrated
- Antenna Qty
- 2
- Power Device
- Internal power supply
- Included Accessories
- HomePlug AV Ethernet Adapter
- OS Required
- 11.2 cm
- 7.7 cm
- 5.3 cm
- 0 °C
- 40 °C
- 20 - 95%
